Does intake make any difference
The intakes won't add much hp wise but sound pretty bad as$ at WOT over 3500rpm and look nicer in the engine bay, especially the ones w/ the longer polished tubes. Not much you can do to the VQs to boost output without putting serious coin into turbo or supercharger kits. The High flow cats are a better mod for sheer gains, again it's not much but a bit more than intakes.
There's not much you can do to this engine short of forced induction that will net you double digit HP boost in one fell swoop. intakes, depending on which ones you get, can add anywhere between 3-8hp, depending on a LOT of factors, including which tune you get, if any, temperature, location, and altitude.
Not much HP but +1 for SOUND!! You can't go wrong with R2C or stillen Gen 3!! All depends how you drive your car. I personally chose R2C bc its a mid range CAI felt/heard at 3500-4000 rpm. Stillen Gen 3 is more of a high range band 6000-7000 range. I dont know about you but I spend more time in the mid range band as opposed to higher range for a DD that is. Tracking is a different story.
I felt a slight difference when i put my Status Elite intakes on mine, it seems to have gone away though. Or im just used to it now. Either way they sound awesome at wide open throttle, ecspecially when in a tunnel or in the fast lane next to a jersey barrier.
superjoey
31
Mar 22, 2023 11:56 PM
