New G37xs coupe owner winter tires question
Old Aug 3, 2012 | 02:40 PM
McBoss's Avatar
McBoss
Hey guys. I just purchased a new G37 and wanted to know if the tire rating 225/45-17 off set would work?
Old Aug 7, 2012 | 10:50 PM
G37Vert's Avatar
G37Vert
The number you are asking about is not teh offset it's the tire size. That tire should work if it fits your wheel.
Old Aug 8, 2012 | 05:33 PM
McBoss's Avatar
McBoss
alright thanks! yeah gotta buy some new wheels for the winter
Old Aug 9, 2012 | 01:13 PM
Brandisher's Avatar
Brandisher
Also make sure they clear your brakes, if you are running akebono brakes
Old Aug 10, 2012 | 02:12 PM
volnedan's Avatar
volnedan
You might want to check your ratio to make sure it doesn't cause a problem with your VDC. I believe the AWD coupe tires are 225/50R18? If you go down to 17", I think you need to be 225/55R17. I would either check the wheel/tire forum or just call Tire Rack.
Old Aug 10, 2012 | 06:25 PM
cnagy65's Avatar
cnagy65
If you have an xs coupe then you have the sport brakes and 19 tires. The 17's wont fit over the brakes.
james6980
Oct 9, 2015 01:28 PM
drive6MT
Sep 14, 2015 12:36 PM
drewfinity
Aug 20, 2015 08:17 PM
mitchlt
Aug 20, 2015 03:44 PM
