Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
What do you guys use to extract extra brake fluid from the reservoir?
Old Aug 28, 2016 | 07:04 AM
4DRZ's Avatar
4DRZ
For years I had a small plastic extractor that worked really well and did not leak, but the handle finally broke. I thought I got it at Winding Road Racing, but I do not see anything similar there and the auto parts stores here are coming up blank.
What do you use that works well and does not leak for pulling out extra brake fluid from the master cylinder reservoir when you swap to newer/thicker pads at track days? Thanks!
Old Aug 28, 2016 | 08:57 AM
PowerBleeder works great to pressure it out through the lines. Clears the old fluid from the entire system, not just the reservoir. If that's all you want to do Mytvac vacuum pump works well. Or a turkey baster.
Old Aug 28, 2016 | 09:09 AM
stealthee's Avatar
stealthee
As suggested a turkey baster would do the job just fine or you could even use a child's medicine syringe like they use to give babies cold medicine or the like.
Old Aug 28, 2016 | 09:28 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I bought a pack of these on amazon a while back. Something like $10 for a 10pack.
What do you guys use to extract extra brake fluid from the reservoir?-yiqb1ut.jpg
Great for sucking fluid out of the brake/clutch reservoir's and power steering. Attach a small hose for more flexibility.
Old Aug 28, 2016 | 11:04 AM
stealthee's Avatar
stealthee
Yeah, that's the syringe I was trying to explain. Should work great,
Old Aug 28, 2016 | 11:47 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I've used a turkey baster before. They just don't seal very well. These things are medical grade and get the job done.
Note, label which one is used for what so you don't contaminate fluids.
Old Aug 28, 2016 | 02:45 PM
4DRZ's Avatar
4DRZ
Awesome, thanks! That looks very similar to what I was using in the past. Sounds like it seals well for you too? That had a turkey baster at Advanced Auto parts, but we tested it with water and it leaked all over the place and the last thing I want is to leak brake fluid on my paint as I pull it out of the engine bay.
Old Aug 29, 2016 | 07:39 AM
Splitter's Avatar
Splitter
I have a 20ml syringe that I use. Nice and thin so it gets right to the bottom of the brake, clutch and power steering reservoirs.
If you have a pet shop (maybe?), or even horse/livestock feed shop (ie, Tractor Supply) nearby you can buy single units there for cents.
I tried the turkey baster and just made a mess of things, it's now in the bin. Don't waste your time or money.
Old Aug 29, 2016 | 11:30 AM
4DRZ's Avatar
4DRZ
I was thinking maybe Target or Wal Mart would have something, but I'll swing by a pet store or we have a place called Fleet Farm that might have them.
Don't worry about the turkey baster. After testing it in the store with water it was pretty obvious that would never work.
Old Aug 29, 2016 | 12:40 PM
RadioFlyer's Avatar
RadioFlyer
They also use those giant syringes for glue at furniture repair places and woodworking places. You could check if there is one of those near you.
Old Aug 29, 2016 | 12:44 PM
slartibartfast's Avatar
slartibartfast
A lab supply vendor can help. We used large syringes to inject gaseous samples into a gas chromatograph. Alpha Aesir and Sigma-Aldrich are two we used.
Old Aug 29, 2016 | 01:29 PM
4DRZ's Avatar
4DRZ
Man you guys are a wealth of information today. I should be able to find these somewhere in town. Thanks!
Old Aug 29, 2016 | 01:41 PM
JSolo's Avatar
JSolo
Just say no!!!!!
We take our syringes seriously around here
Old Aug 29, 2016 | 02:09 PM
4DRZ's Avatar
4DRZ
Haha! I guess so. And these don't even have any needles
Old Aug 31, 2016 | 03:50 PM
4DRZ's Avatar
4DRZ
I picked up a 3 pack of syringes at Fleet Farm yesterday for about $3 which will probably last me a decade. You are supposed to thread a needle into the end, but I think they will work fine. They definitely seal a lot better than the one I was using and are even sterilized since they are for animal use. My brake fluid never had it so good.
