Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Cali Speedway stock G37 7AT sedan results...
Old Mar 7, 2009 | 08:59 PM
REKKO's Avatar
REKKO
After seeing what the car put down on the dynojet on Feb. 21st https://www.myg37.com/forums/g37-sed...jet-today.html I was now ready to see what the car can do down the 1/4 mile at the track. From now on I will refer to the track as AAA Speedway because that is what they have changed the name to since I was there, 6 years ago.
Anyway, I got checked in and was on my way. I was the only 07+ G out there, coupe or sedan. There were 3 others running but only talked to one of them which was a gen 1 coupe that was running a turbo in the low 13's.
My car is completely stock other than the BB wires. It was a clear day with temps hovering around 65 degrees. My first run I lowered tire pressure to 33 psi for the rears, DS mode, VDC off. I drove around the water box and slammed the gas to clean off the tires. I lined up, power braked to 1100 rpms, left on the 3rd light and slammed the gas not looking back. Wheel spin was non existent on this run. Ended up with a 14.04 at 99.44 mph.
The next run was the same except this time I dropped the tires down to 31 psi and power braked to around 1400. I had just a little wheel spin and was off, this time just dipping into the 13's at 99.88 mph. All in all I had a great time and was very pleased with the results seeing as the car is stock and still pretty fresh ( purchased on January 31st of this year ).
Comparing cars, there were quite a few 350z's with bolt ons running in the low-mid 14's with similar trap speeds and 335's, both stock and chipped, in the low 14's and mid -high 13's with trap speeds between 103 and 108. I believe this tracks altitude is @ 1350'.
So now the modding begins...
Old Mar 8, 2009 | 10:13 PM
catlover52's Avatar
catlover52
did you switch your oil to syn ester?
Old Mar 9, 2009 | 12:35 AM
REKKO's Avatar
REKKO
I'm still running on the oil that came from the dealer, only a little over 2G on the odometer. I really haven't gotten into the whole oil thing yet. I know there has been a lot of debate on this. For the last 15 years I have been running Mobil 1 synthetic. I was planning the same with this car.
Old Mar 9, 2009 | 10:05 AM
terrycs's Avatar
terrycs
Nice!
Old Mar 12, 2009 | 03:19 AM
g14classified's Avatar
g14classified
what does infiniti claim the car runs on the 1/4 13.8? someone correct me if im wrong.
Old Mar 12, 2009 | 12:06 PM
skaterbasist's Avatar
skaterbasist
The same car that can run 13.5 at one place (Motortrend got this time) can run 14's at another place.
Anyhow, I wished I could have made it to this event. I would have surely made it past the 13.9 mark considering that I did 14.3 @ 99 with a weak 2.2 60ft at this track when it was almost 100 degrees hot with less mods and no tune
Old Mar 12, 2009 | 12:39 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Nice times man. Congrats
Old Mar 12, 2009 | 12:42 PM
aliiin's Avatar
aliiin
BMW Defector
nice man... don't let the mod bug bite you!
Old Mar 12, 2009 | 01:30 PM
da mayor's Avatar
da mayor
your mph should go up no problem. it's just getting used to the track condition and how to launch your car. sounds like you had fun!
slowbird
Aug 3, 2023 07:54 PM
maybeg37
Sep 8, 2015 02:33 PM
em1990
Aug 11, 2015 01:22 PM
SS2006
Aug 9, 2015 05:32 PM
