Help stillen oil cooler
Old Feb 11, 2014 | 12:19 AM
handleandrew's Avatar
handleandrew
so, to anyone who may read this in the future:
I called Stillen and sent them the above pictures, they could not explain the difference between the smaller filter in the instructions and the larger filter sent with the kit. I ended up just putting a 2" extension on the existing coolant line. pictures below. its 1/2" line.
Old Feb 11, 2014 | 12:25 AM
handleandrew
the other thing that I changed with the install was the location of the actual cooler in the front. the directions relocate the power steering cooler so that you can use the mount for the oil cooler but then it blocks the air going to the power steering cooler, sandwiching it between the radiator and oil cooler so I moved it over a bit, still had long enough oil cooler lines and just drilled one hole in the bracket.
2 directions photos:
I moved it over , like this:
Old Feb 11, 2014 | 12:52 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
That's probably where your slack went.
Old Feb 11, 2014 | 09:02 AM
GoFightNguyen
Because Racecar
I'm glad you got it sorted though, add checking that extension and oil cooler fittings to your maintenance schedule.
Old Feb 11, 2014 | 05:57 PM
TVPostSound's Avatar
TVPostSound
GoFightNguyen
You dont have a factory oil cooler, the OP does, hence the extra plate.
Heres a DIY from 370Z
http://www.the370z.com/diy-section-d...er-delete.html
Old Feb 12, 2014 | 09:11 AM
GoFightNguyen
Because Racecar
GoFightNguyen
DIY 2012 25 row Setreb Series 9 Install & stock oil cooler delete - Nissan 370Z Forum
I'm aware that my car didn't come with a factory oil cooler, but I thought that no infiniti comes with an OEM oil cooler. The 370z's might, but OP has a G37...
Old Feb 12, 2014 | 07:44 PM
TVPostSound
Is this a 6MT thing??
Old Feb 12, 2014 | 07:48 PM
GoFightNguyen
Because Racecar
Nope, I'm 7at
Old Feb 12, 2014 | 11:59 PM
handleandrew
Attachment 101971
slack wasn't the solution to, or cause of, my problem. it was the angle of the connections. the hoses could have been 2 feet long or 20 feet long. it would have changed nothing.
the lines that came with the oil cooler are steel. the binding hose was rubber, the factory hose. it has coolant in it, not oil.
Old Feb 13, 2014 | 12:16 AM
handleandrew
GoFightNguyen
what is an OP?
Old Feb 13, 2014 | 12:32 AM
handleandrew
I have a 2008 G37S with a MT, and that same plate is pictured in the stillen directions I posted above, so, maybe? also possibly because it is a Sport?
similar to the 370Z post above the Stillen said you can just by pass the stock cooler by routing the coolant lines as described in the 370 post, it just seemed like less work to lengthen that stock rubber line. took 5 mins.
maybe they were only on the older models? (08-11)?
Old Feb 14, 2014 | 12:28 AM
TVPostSound
Originally Posted by handleandrew
what is an OP?
Original Poster
Old Feb 16, 2014 | 06:09 PM
Synolimit's Avatar
Synolimit
You just need to remove the OEM cooler. It serves no purpose once an oil cooler is installed. You're just heating up the coolant more than it needs to be and hotter coolant will generate hotter oil temps. Its a vicious cycle. An aftermarket radiator does wonders for oil temps.
beng37s
Dec 8, 2019 01:21 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Chappedj
Sep 28, 2015 03:20 PM
SON415
Sep 28, 2015 05:49 AM
