Help Traction control and slip light stuck on
Old 12-01-2011, 09:05 PM
37hevn
37hevn's Avatar
I recently dynoed my car and as usual when i drove off the vdc and slip light and abs light were on but went off in just a few seconds of driving. I then turned it off and everytime i start my car now my lights are off but when i get over 20 mph my traction control and slip light come on and stay on. The vdc button doesnt do anything. Ive unplugged my battery and tried to clear it with Cipher but Cipher doesnt pick it up. Ive read that it resets when you turn off the vehicle and it does go off but then comes back on when i start driving. I just put new brakes on this spring so I doubt its brakes. Let me know.
Old 12-01-2011, 09:07 PM
AvosG37
AvosG37's Avatar
happened to me before. i took it to dealer n they fixed it under warrenty. idk wat was it
Old 12-01-2011, 09:08 PM
Modme
Modme's Avatar
Car needs an alignment.
abrecos (09-06-2020)
Old 12-01-2011, 09:13 PM
37hevn
37hevn's Avatar
That makes sense, I had headers put on and the steering column had to be taken off and we have put it on a couple ways but its still a bit off. I just need more time to get it right. Since it has to be put on a lift it takes time. Thanks!
Old 06-02-2015, 01:33 PM
kmartinjr
kmartinjr's Avatar
Did the alignment fix the problem? I'm having the same exact issues...
Old 06-02-2015, 06:49 PM
former520
former520's Avatar
Check your break fluid level. I had the same issue after a break job and the fluid was in the middle of the range. Topped it up and no more issues.
Old 06-02-2015, 11:16 PM
kmartinjr
kmartinjr's Avatar
Topped off the brake fluid... still coming on... so it might be an alignment issue... seems like everytime the front wheels slip from a bump they come on.... maybe a bad sensor.... having it checked tomorrow those three lights aggravate the hell out of me... Any one know if wheels would have anything to do with it?
Old 06-25-2015, 06:06 PM
l50k
l50k's Avatar
normally its the brake fluid . I would check for codes
Old 03-18-2020, 05:06 AM
treaty
treaty's Avatar
My traction control light comes on when i take off and its dry out what could be the issue before I go to the dealer tonight. im thinking i might have caliper seized up???
Old 03-21-2020, 01:07 PM
Conboss
Conboss's Avatar
just traction control? Is it just flashing? Are you just slipping...?
Old 03-21-2020, 06:15 PM
Surfnazi
Surfnazi's Avatar
Check brake fluid level
goredcar
03-22-2016 05:50 PM
gammamotors
44
12-31-2015 12:48 AM
TheLocNar
12-22-2015 07:52 PM
inspector94
09-08-2015 12:57 PM
Quick Reply: Help Traction control and slip light stuck on
