lowering
Old Jun 2, 2011 | 12:32 AM
  #31
canfromet's Avatar
canfromet
i know, but i just found out about their price and i can't afford them
Old Jun 21, 2011 | 02:35 AM
  #32
Fugy's Avatar
Fugy
Originally Posted by G37Sam
Eibach Springs, 25mm spacers front, 20mm spacers rear:
Don't waste your money on coils if you're not tracking or need to adjust height for summer & winter IMO
Any issues with rubbing? Thx
Old Jun 22, 2011 | 03:34 AM
  #33
G37Sam's Avatar
G37Sam
Not anymore, they just peeled off or something I guess
Old Dec 22, 2011 | 11:09 PM
  #34
Brink2011's Avatar
Brink2011
So, with stock tires you can get by with 20mm spacers all-around is the way to go. Once my stock tires are dead, I want to put on 245/40 and 275/35, and am considering 1 of 3 options... what do you guys think?
1. 15mm all-around
2. 20mm all-around
3. 15mm front, 20mm rear
Old Dec 22, 2011 | 11:17 PM
  #35
TVPostSound's Avatar
TVPostSound
1. 15mm all-around
2. 20mm all-around
I have 15MM all around with the 245/275 combo.
Had 20MM all around but tires stuck out in the rear.
Should have gone option 4
20MM front, 15MM rear.
Yes I wrote that correctly, wider spacers in the front. Just like G37Sam, and Devildog37
Im on Michelin Pilot Super Sports, they run wide.
Old Dec 23, 2011 | 12:32 AM
  #36
jujubii's Avatar
jujubii
1. 15mm all-around
2. 20mm all-around
im on stock 18s stock tires eibach drop and option 3
you can look for my pictures under mediashare, i coudl take more pics if you want. personally, i woudl do 20s all around, but for some reason my brakes squeal alot more when i have 20s in the front versus 15s. coudlnt figure out why but i think its attributed to the OEM pads or warped rotors (i noticed that they start to get more glazed after i installed them). no one seems to have the same issue as me though...
Old Dec 23, 2011 | 03:00 PM
  #37
TVPostSound
A small, maybe insignificant benefit of having 10MM more track on the front wheels is, minimizing understeer.
Our G37s have a narrower front track already. Evening it out could help.
Old Jan 15, 2012 | 10:32 AM
  #38
Jadex153's Avatar
Jadex153
I'm sitting on Eibach's right now, but about a week ago I put 20" ASA rims on my car. Now I'm thinking about getting Tein S-tech's, maybe even something a touch lower. Can't do coilover's, though. My car throws me around enough lol.
Old Jan 26, 2012 | 09:06 PM
  #39
seymore4's Avatar
seymore4
just throwing it out there but be careful what spacers you get, I've heard of some of the cheaper ones causing wobbling/ vibration due to not being individually balanced at the factory...
Old Jan 9, 2014 | 10:35 PM
  #40
MVick's Avatar
MVick
where you running camber at all?? or was it set to factory, and did you have to cut brackets or roll fenders?
Old Apr 13, 2015 | 06:25 PM
  #41
Eyeshield25's Avatar
Eyeshield25
Bump on this ^^
Old Oct 18, 2015 | 06:21 AM
  #42
hooey_b's Avatar
hooey_b
Originally Posted by Doggy
Just do your research before anything, I'm dropped on s-techs and it sits really low, IMO I like s techs drop it looks slammed! Eibach is a mild drop, barely noticeable which I personally don't like, the rest only gets Dropped .8 I think and the front an inch to get rid of the wheel gap. With eibachs camber kits aren't needed, with s tech its needed unless you wana flip the tires every few thousand. IMO if your going to lower it slam it!
Just be careful of big bumps and steep driveways. And spacers go 20mm all around and that should sit flush
i've got tein s-techs as well, but no camber correction. it's definitely recommended, and it's the next thing on my list of sh*@ to do. to me, i can barely notice the eibach drop unless i LOOK at it. the teins look great. i WAS running 225/35/19 245/35/19 originally, but have had to change my tires since (lowered in april, new *used* tires in august). waited 10 days before getting an alignment, and i have NO sound issue except going into my steep driveway.
keep away from anything slimmer than 40 and you shouldn't scrape too much @ all.
MyG37 - hooey_b's Album: Garage - Nina - Picture
misc
29
May 24, 2023 03:57 PM
37
Oct 17, 2020 11:12 AM
Awgd8
Sep 30, 2015 06:22 PM
k19g37x
Sep 29, 2015 02:46 PM
