Help shift knob not in park when it is?
Old Jun 4, 2009 | 11:05 AM
g37mobbin's Avatar
g37mobbin
shift **** not in park when it is?
So today, i decided on working on getting my center console out and my radio console pieces off the manual says to put in Neutral before removing the shift **** and center console. So i do that. Everything went smooth until i put back the pieces together. then it tell me Park up shift...or more like shift to park but when i do it does not read it or sense it. Anyone experience problem or know how to fix it?<!-- google_ad_section_end -->
Old Jun 4, 2009 | 04:03 PM
aznutx's Avatar
aznutx
no idea, maybe double check u reconnected everything correctly and snuggly, then maybe reset ecu, i got no idea
Old Jun 4, 2009 | 05:41 PM
HamstersG's Avatar
HamstersG
Did you disconnect the battery before you did the work and leave it disconnected until you got everything done and it back in park?
Old Jun 4, 2009 | 08:01 PM
jnguyen's Avatar
jnguyen
you sure it says to put in neutral? I put mine in drive with my parking brakes on.
Old Jun 5, 2009 | 03:40 AM
g37mobbin's Avatar
g37mobbin
yeah it says neutral but dont know where i went wrong? it is really odd...i would take it to my local infiniti dealership but i took my headlight and grill off so i can get some projects done and been doing things to the interior till this came up....
Old Jun 5, 2009 | 04:49 AM
STOOF's Avatar
STOOF
when you put the shift console back on, did you stick the shifter through the square piece underneath that slides. Sounds like you might not have and its not letting it go all the way up into park.
Old Jun 5, 2009 | 11:45 AM
g37mobbin's Avatar
g37mobbin
it stops right before the plastic thing that is "suppose" to lock it. Here is the picture i have of my problem.
37
Oct 17, 2020 11:12 AM
vamarris
Dec 9, 2018 11:10 AM
ANMVQ
Dec 8, 2016 04:55 PM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
