Special New FREE Car Care Product every week at DetailedImage.com
Auto Detailing Expert
This week's Weekly Special is Rupes Medium Wool Pad - 3.5".
Use Coupon Code WSMEDIU2018 to receive it for Free. A $10.99 value! Min spend $55. Offer ends 5/22/18 at 11:59 PM EST.
- Remove medium imperfections fast and easy!
- Works best on high powered buffers, for fast, effective paint correction
- Pair with a medium polish for best results
This week's Weekly Special is Kwazar Mercury Pro+ Sprayer - 1000 ml.
Use Coupon Code WSMERCU2118 to receive it for Free. A $16.99 value! Min spend $85. Offer ends 5/29/18 at 11:59 PM EST.
- High quality spray bottles for any step in the detailing process
- Unique double action trigger that reduces hand fatigue
- Labeled in both ML and Pints
- Viton seals that resist most chemicals
This week's Weekly Special is DI Accessories Chemical Resistant Spray Trigger - High Volume.
Use Coupon Code WSCHEMI2218 to receive it for Free. A $3.99 value! Min spend $10. Offer ends 6/5/18 at 11:59 PM EST.
- A high quality trigger meant to withstand strong cleaning agents
- Can spray a fine mist or a direct stream
- Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
- Comes in two great styles, Standard and High Flow
This week's Weekly Special is P21S Bodywork Conditioning Shampoo - 500 ml.
Use Coupon Code WSBODYW2318 to receive it for Free. A $11.99 value! Min spend $50. Offer ends 6/12/18 at 11:59 PM EST.
- An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
- Only a cap full of shampoo is needed in a 5 gallon bucket of water
- The low sudsing formula does not make this a great shampoo for a foam gun
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
This week's Weekly Special is Menzerna Heavy Cut Compound 400 - 8 oz.
Use Coupon Code WSHEAVY2418 to receive it for Free. A $19.99 value! Min spend $110. Offer ends 6/19/18 at 11:59 PM EST.
- Easily remove heavy imperfections while leaving behind a high gloss finish!
- Apply with a cutting pad (i.e. Lake Country Orange Light Cutting Pad, Surbuf R Series MicroFingers Buffing Pads or Optimum Microfiber Cutting Pad)
- Very low dusting which makes for easy cleanup
- On darker finishes follow up with a finer Menzerna polish like the Power Finish PF 2500, Super Finish Polish SF 4000 or Micro Polish SF 4500
- Premium medium to heavy cutting polish, that finishes down extremely well!
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL2518 to receive it for Free. A $19.99 value! Min spend $85. Offer ends 6/26/18 at 11:59 PM EST.
- Degrease nearly any surface safely and effectively
- Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
- Can be used at full strength or diluted down to clean more delicate surfaces
- Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
- A must have any detailing enthusiasts or pro detailers arsenal of products
This week's Weekly Special is 22ple Glass Coat Applicator (Double Sided).
Use Coupon Code WSGLASS2618 to receive it for Free. A $5.99 value! Min spend $35. Offer ends 7/3/18 at 11:59 PM EST.
- High quality applicator pad for applying your favorite coating
- Two sided for double the use!
- Will not soak up excess product, applications are easier and you waste less product
- One of the most efficient ways for applying your 22ple coatings
This week's Weekly Special is Tuf Shine Tire Brush.
Use Coupon Code WSTIREB2718 to receive it for Free. A $4.99 value! Min spend $30. Offer ends 7/10/18 at 11:59 PM EST.
- Great for deep cleaning the tires
- Use with the TUF SHINE Tire Cleaner or your favorite degreaser
- Strong yet gentle bristles
- Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
This week's Weekly Special is Lake Country HDO Black Finishing Pad - 6.5".
Use Coupon Code WSHDOBL2818 to receive it for Free. A $15.99 value! Min spend $65. Offer ends 7/17/18 at 11:59 PM EST.
- Leaves behind an incredible level of clarity with a flawless finish!
- Pair with your favorite finishing polish
- Runs 10% cooler than traditional Lake Country pads
- Perfectly balanced, cushioned, and features thinner foam
This week's Weekly Special is The Rag Company Spectrum 420 Microfiber Towel Grey - 16" x 16".
Use Coupon Code WSSPECT2918 to receive it for Free. A $3.99 value! Min spend $10. Offer ends 7/24/18 at 11:59 PM EST.
- Tackle any detailing step safely and easily
- Longer nap great for removing loose contamination or wax, sealant, etc.
- Shorter nap removes tightly bonded particles like road grime or excess polish
- 70% Polyester / 30% Polyamide (420 GSM)
- Durable and high quality towel
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt with thumb.
Use Coupon Code WSSHEEP3018 to receive it for Free. A $12.99 value! Min spend $50. Offer ends 7/31/18 at 11:59 PM EST.
- Natural fibers create a super soft wash medium to help minimize the possibility adding swirls and other imperfections
- Incredibly soft fibers break up contaminants and release the contaminants
- Free flowing water rinses the mitt clean, wring it out and hang dry with leather loop
- One size fits all design makes it perfect for a small to extra large size hand
- Also available in the without thumb version!
This week's Weekly Special is DI Brushes Leather and Vinyl Scrub Brush.
Use Coupon Code WSLEATH3118 to receive it for Free. A $4.99 value! Min spend $25. Offer ends 8/7/18 at 11:59 PM EST.
- Outstanding leather care brush to deep clean leather!
- Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
- Soft and gentle leather brush that works great
This week's Weekly Special is Kenotek Brilliant Wash - 1000 ml.
Use Coupon Code WSBRILL3218 to receive it for Free. A $18.99 value! Min spend $110. Offer ends 8/14/18 at 11:59 PM EST.
- Extremely slick shampoo with gentle cleaning power!
- pH neutral and safe for underlying protection layers
- Awesome grapefruit scent
- Does not strip wax, sealant or coatings
This week's Weekly Special is Nextzett Scheiben Klar Windscreen Clear Glass Cleaner - 500 ml.
Use Coupon Code WSSCHEI3318 to receive it for Free. A $8.99 value! Min spend $35. Offer ends 8/21/18 at 11:59 PM EST.
- Use as is or dilute up to 2:1 ratio for maximum value
- Powerful glass cleaner that leaves your windows streak free every time
- Ammonia free formula
This week's Weekly Special is 3D Speed - 8 oz.
Use Coupon Code WSSPEED3418 to receive it for Free. A $7.19 value! Min spend $40. Offer ends 8/28/18 at 11:59 PM EST.
- Polish and protect in one step!
- Removes swirls, oxidation, and ultra fine scratches
- Leaves behind wax like protection
- Applies and removes with ease
- Outstanding value!
superjoey
31
Mar 22, 2023 11:56 PM
Detailed Image
Lighting/Cleaning Products
Aug 3, 2015 02:44 PM
