Special New FREE Car Care Product every week at DetailedImage.com
#331
This week's Weekly Special is DI Microfiber Applicator Pad - Rectangle.
Use Coupon Code WSAPPLI4217 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 10/24/17 at 11:59 PM EST.
- Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
- Very soft and safe applicator
- It should last years if you hand wash the Microfiber Applicator
- Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
- 300 GSM and reusable!
- Comes in two great shapes, rectangle and circle!
#332
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL4317 to receive it for Free. A $19.99 value! Min spend $105. Offer ends 10/31/17 at 11:59 PM EST.
- Degrease nearly any surface safely and effectively
- Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
- Can be used at full strength or diluted down to clean more delicate surfaces
- Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
- A must have any detailing enthusiasts or pro detailers arsenal of products
#333
This week's Weekly Special is Lake Country CCS Orange Light Cutting Pad - 5.5".
Use Coupon Code WSCCSOR4417 to receive it for Free. A $7.99 value! Min spend $30. Offer ends 11/7/17 at 11:59 PM EST.
- Great pad for applying your favorite polish
- CCS dimple technology reduces friction and heat
- We recommend caring for your pads with Snappy Clean Pad Cleaner
- For best results, follow up with the CCS White Polishing Pad and your favorite finishing polish
- Helps work in medium to heavy cutting polishes
#334
This week's Weekly Special is DI Microfiber Green Monster Hybrid Car Wash Mitt - 9" x 9".
Use Coupon Code WSGREEN4517 to receive it for Free. A $10.99 value! Min spend $35. Offer ends 11/14/17 at 11:59 PM EST.
- Safely remove dirt and grime from your paint
- Different lengths of microfiber help clean the micro-ridges of your clear coat
- Can be used as a wash pad or wash mitt
- Measures 9" x 9"
#335
This week's Weekly Special is Lake Country Snappy Clean Boost Pad Cleaner.
Use Coupon Code WSSNAPP4617 to receive it for Free. A $1.49 value! Min spend $5. Offer ends 11/21/17 at 11:59 PM EST.
- A citrus degreaser designed to help release product and contamination from foam pads
- Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
- To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
#336
Use Coupon Code WSAPPLI4717 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 11/28/17 at 11:59 PM EST.
- Comes in three great varieties!
#337
This week's Weekly Special is DI Accessories Precision Bug Scrubber.
Use Coupon Code WSPRECI4817 to receive it for Free. A $6.99 value! Min spend $30. Offer ends 12/5/17 at 11:59 PM EST.
- Helps you easily remove dirt, grime, bug splatter, and more
- Easy to hold, lightweight handle design
- Six sided shape makes cleaning a breeze
- Rinses clean with ease
#338
This week's Weekly Special is DI Microfiber Double Thick Edgeless Towel - 16"x16" Blue.
Use Coupon Code WSDOUBL4917 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 12/12/17 at 11:59 PM EST.
- Edgeless design saves you time while improving results!
- Very plush, long, and soft microfiber threads
- Very durable design that can be machine washed
- Can be used for virtually any detailing task
- 470 GSM
#339
This week's Weekly Special is DI Brushes Foam Pad Cleaning Brush.
Use Coupon Code WSFOAMP5017 to receive it for Free. A $1.99 value! Min spend $10. Offer ends 12/19/17 at 11:59 PM EST.
- Helps remove excess product trapped in your buffing pad
- Safe on all foam pads and very easy to use
- Helps prolong the life of pads and keep them in ideal working condition
- 8" contorted handle and .75" nylon bristles
#340
This week's Weekly Special is Rupes White Finishing Foam Pad - 1.25".
Use Coupon Code WSWHITE5117 to receive it for Free. A $6.99 value! Min spend $30. Offer ends 12/26/17 at 11:59 PM EST.
- Bring back that deep glossy finish safely and easy!
- Removes ultra fine imperfections and finishes down extremely well
- Pairs great with the Rupes Diamond Ultra Fine Gel Polish
#341
This week's Weekly Special is Lake Country Force White Polishing Pad - 3.5".
Use Coupon Code WSFORCE5217 to receive it for Free. A $4.99 value! Min spend $25. Offer ends 1/2/18 at 11:59 PM EST.
- Remove fine imperfections like swirls, spider webs, oxidation, etc.
- Pair with your favorite finishing polish
- Hybrid foam technology keeps the polish on the surface of the pad
- We recommend cleaning and caring for your pads with the Lake Country Snappy Clean Boost Pad Cleaner
#342
This week's Weekly Special is Lake Country Microfiber Polishing Pad - 5.25".
Use Coupon Code WSMICRO0118 to receive it for Free. A $10.99 value! Min spend $40. Offer ends 1/9/18 at 11:59 PM EST.
- Remove light to medium imperfections with ease
- A great compliment to Lake Country Microfiber Cutting Pads
- Foam backed and 11mm thick design
- Unique microfiber material mats down less reducing surface temperature
- Finishes down extremely well!
#343
This week's Weekly Special is Chemical Guys Maxi Suds II - 16 oz.
Use Coupon Code WSMAXIS0218 to receive it for Free. A $8.99 value! Min spend $35. Offer ends 1/16/18 at 11:59 PM EST.
- One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
- An addicting cherry scent that makes washing your car a pleasure
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
- High sudsing formula makes this a great option to use in foam guns
#344
This week's Weekly Special is DI Accessories Fine Grade Clay Bar - 100 g.
Use Coupon Code WSFINEG0318 to receive it for Free. A $10.99 value! Min spend $25. Offer ends 1/23/18 at 11:59 PM EST.
- Safely remove road grime, brake dust, tar, sap, paint over spray and more
- Fine grade clay bars are gentle on your exterior paint
- We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
- Can be used on brand new cars to older vehicles with light to medium build ups
#345
Use Coupon Code WSFOAMP0418 to receive it for Free. A $1.99 value! Min spend $10. Offer ends 1/30/18 at 11:59 PM EST.
