Special New FREE Car Care Product every week at DetailedImage.com
Old Aug 3, 2016 | 08:14 AM
  #271
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
This week's Weekly Special is DI Brushes Pet Hair Removal Brush.
Use Coupon Code WSPETHA3116 to receive it for Free. A $3.74 value! Min spend $25. Offer ends 8/9/16 at 11:59 PM EST.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
Old Aug 17, 2016 | 08:47 AM
  #272
Detailed Image
This week's Weekly Special is P21S Paintwork Cleanser - 350 ml.
Use Coupon Code WSPAINT3316 to receive it for Free. A $15.99 value! Min spend $95. Offer ends 8/23/16 at 11:59 PM EST.
  • Properly preps your paints surface prior to applying a wax while adding depth and gloss
  • Best applied just after polishing your paint to remove imperfections
  • Can be applied either by hand with a foam applicator pad or via buffer and a black or blue pad
  • Excess product should be removed with a quality microfiber towel
Old Aug 24, 2016 | 08:22 AM
  #273
Detailed Image
This week's Weekly Special is Rupes White Finishing Foam Pad - 1.25".
Use Coupon Code WSWHITE3416 to receive it for Free. A $6.99 value! Min spend $25. Offer ends 8/30/16 at 11:59 PM EST.
  • Bring back that deep glossy finish safely and easy!
  • Removes ultra fine imperfections and finishes down extremely well
  • Pairs great with the Rupes Diamond Ultra Fine Gel Polish
Old Aug 31, 2016 | 08:25 AM
  #274
Detailed Image
This week's Weekly Special is 22ple Glass Coat Applicator (Double Sided).
Use Coupon Code WSGLASS3516 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 9/6/16 at 11:59 PM EST.
  • High quality applicator pad for applying your favorite coating
  • Two sided for double the use!
  • Will not soak up excess product, applications are easier and you waste less product
  • One of the most efficient ways for applying your 22ple coatings
Old Sep 7, 2016 | 08:30 AM
  #275
Detailed Image
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL3616 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 9/13/16 at 11:59 PM EST.
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
Old Sep 14, 2016 | 08:26 AM
  #276
Detailed Image
This week's Weekly Special is DI Microfiber Applicator Pad - Rectangle.
Use Coupon Code WSAPPLI3716 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 9/20/16 at 11:59 PM EST.
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
Old Sep 21, 2016 | 08:42 AM
  #277
Detailed Image
This week's Weekly Special is 303 Automotive Speed Detailer - 16 oz.
Use Coupon Code WSAUTOM3816 to receive it for Free. A $6.74 value! Min spend $40. Offer ends 9/27/16 at 11:59 PM EST.
  • Clean, shine and protect paint with ease
  • Adds protection to resist contamination and UV rays
  • Spray on and wipe off easy application
  • Can be used on paint, glass, fiberglass, plastic, metal, etc.
Old Sep 28, 2016 | 08:20 AM
  #278
Detailed Image
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel - 36" x 24".
Use Coupon Code WSWAFFL3916 to receive it for Free. A $17.99 value! Min spend $90. Offer ends 10/4/16 at 11:59 PM EST.
  • Dry your vehicle safely and quickly
  • Continues to soak up large amounts of water even after it's damp or wet
  • A fine silk edging ensures this is a safe towel
  • This towel can hold up to 10 times its weight with water
  • Use this towel with the sheeting method for the most efficient drying process
  • 480 GSM
Old Oct 6, 2016 | 08:40 AM
  #279
Detailed Image
This week's Weekly Special is CarPro Iron X Iron Remover Cherry Scent - 500 ml.
Use Coupon Code WSIRONX4016 to receive it for Free. A $18.99 value! Min spend $90. Offer ends 10/11/16 at 11:59 PM EST.
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
  • Also available in Lemon Scent!
Old Oct 12, 2016 | 08:31 AM
  #280
Detailed Image
This week's Weekly Special is Chemical Guys DeCon Pro Iron Remover - 16 oz.
Use Coupon Code WSDECON4116 to receive it for Free. A $16.99 value! Min spend $90. Offer ends 10/18/16 at 11:59 PM EST.
  • Removes iron deposits from paint and wheels
  • Remarkably quick, effective and easy to use cleaner
  • Gel formula changes to a deep purple when dissolving iron deposits
Old Oct 19, 2016 | 08:21 AM
  #281
Detailed Image
This week's Weekly Special is DI Accessories Terry Cloth White Stripe Applicator Pad.
Use Coupon Code WSTERRY4216 to receive it for Free. A $1.49 value! Min spend $5. Offer ends 10/25/16 at 11:59 PM EST.
  • Ideal for interior and exterior applications!
  • Durable and reusable applicator
Old Oct 26, 2016 | 08:34 AM
  #282
Detailed Image
This week's Weekly Special is Rupes Green Medium Foam Pad - 2".
Use Coupon Code WSGREEN4316 to receive it for Free. A $9.99 value! Min spend $60. Offer ends 11/1/16 at 11:59 PM EST.
  • Remove moderate to light imperfections quickly and easily!
  • Works great with the Rupes Quarz Gloss Medium Gel Compound
  • Extremely durable design
Old Nov 2, 2016 | 08:43 AM
  #283
Detailed Image
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt without thumb.
Use Coupon Code WSSHEEP4416 to receive it for Free. A $12.99 value! Min spend $75. Offer ends 11/8/16 at 11:59 PM EST.
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
  • Also available in the with thumb version!
Old Nov 9, 2016 | 08:45 AM
  #284
Detailed Image
Use Coupon Code WSAPPLI4516 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 11/15/16 at 11:59 PM EST.
Old Nov 16, 2016 | 08:37 AM
  #285
Detailed Image
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS4616 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 11/22/16 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
