Save ~30% or more EVERYDAY at DetailedImage.com!
Auto Detailing Expert
Today's Daily special (December 10, 2009) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
- One of the most popular used wash mediums by professional detailers
- Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
- One of the best features of the grout sponge is that it releases contamination very easily
- For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (December 17, 2009) is Dodo Juice Banana Armour Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
- A Dodo Juice hard carnauba wax designed to work exceptionally well on warmer colored vehicles
- Extremely easy to apply and remove, especially when applied in thin layers
- Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
- Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
- Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (December 18, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.83!
- Designed to remove a majority of imperfections in the clear coat
- Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
- Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
- Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
- Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
- When using a buffer, best applied with an orange light cutting pad
- For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Today's Daily special (December 29, 2009) is Chemical Guys EXTREME V.R.T..
Regular Price for 16 oz is $8.99. Today's price is $6.47!
- Very versatile dressing that restores vinyl, rubber and plastic to a clean, low gloss finish
- Properly protect your vinyl and rubber surfaces from UV fading with CG Extreme V.R.T.
- To avoid over spray, we recommend misting Extreme V.R.T. into a microfiber towel to apply
- We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (January 24, 2010) is Meguiar's Vinyl and Rubber Cleaner and Conditioner M40.
Regular Price for 16 oz is $11.99. Today's price is $8.93!
- Clean, condition and UV protect in one step
- Perfect for dash boards, consoles, doors, exterior trim, arm rests, door and window seals and more
- Apply with a microfiber towel or applicator pad
Today's Daily special (January 26, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
- Extend the protection of any sealant or wax
- Increase gloss and depth of your paint, perfect for after a wash
- Promotes tight water beading which helps minimize water spots
- Applies and removes easy with a plush microfiber towel
Today's Daily special (January 27, 2010) is Poorboy's World Natural Look.
Regular Price for 16 oz is $10.99. Today's price is $7.91!
- An outstanding 1 step product that cleans, restores and UV protects
- Works best on leather, vinyl, rubber, plastic, tires and more
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (January 28, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
Today's Daily special (February 3, 2010) is Meguiar's Ultimate Quik Detailer.
Regular Price for 22 oz is $9.99. Today's price is $7.63!
- Increases the depth and gloss of any color vehicle
- Adds a layer of protection with high surface tension which repels water very well
- Perfect product to use after a maintenance wash between details
- Best applied with a plush microfiber towel
Today's Daily special (February 8, 2010) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $7.99. Today's price is $5.67!
Regular Price for 128 oz is $24.99. Today's price is $18.49!
- One of our most powerful degreasers available, designed to easily cut through contamination
- Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
- Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (February 10, 2010) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
- The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
- Optimum Hyper Compound is a great polish to use with a yellow cutting pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (February 11, 2010) is Dodo Juice Light Fantastic Soft Wax.
- A Dodo Juice soft carnauba wax designed to work exceptionally well on lighter colored vehicles
- Can be applied with a foam applicator pad or literally with your bare hands
- Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
- Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (February 12, 2010) is Optimum (OPT) Finish Polish.
Regular Price for 32 oz is $29.99. Today's price is $22.19!
- Optimum's finest finishing polish for maximum gloss and depth
- Long workability in both the sun and shade
- Removes minor surface imperfections such as hazing and holograms
- Best applied with a black finishing pad on a quality buffer
Today's Daily special (February 13, 2010) is Chemical Guys Clear Seal.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
- Clean, polish and protect all of your plastic surfaces, in one easy to use step
- Leave plastic surfaces with a slick layer of protection to help minimize dust from building up
- For accurate product dispensing, we recommend using a 4oz dispenser bottle and applying with a microfiber towel
Today's Daily special (February 14, 2010) is Lake Country Green Very Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
- A very popular polishing pad designed to remove light surface imperfections from the paint
- When you need a tad more bite than a white polishing pad, the green pad is your answer
- Menzerna PO106FF polish is one of the most popular products to use with the green pad
