Save ~30% or more EVERYDAY at DetailedImage.com!
Old Aug 18, 2009 | 10:38 AM
  #361
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
  • Foam based formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
  • For optimal results, give a final wipe down with the low nap, glass microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old Aug 20, 2009 | 10:59 AM
  #362
Detailed Image
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old Aug 20, 2009 | 11:02 AM
  #363
nogoodname's Avatar
nogoodname
Originally Posted by Detailed Image
LOL, good question. A wax should help provide a barrier of protection from your paint, but it all depends on what the bird ate depending if it stains or etches into your clear coat. Bugs and berries can be very acidic.
I like the name though, cracks me up.
what is the best thing you got to protect from those very acidic poop...
they eat through my paint
Old Aug 21, 2009 | 01:10 PM
  #364
Detailed Image
Unfortunately, no matter what protection you have on your paint, if the bird droppings are very acidic, there's not much you can do to fight it. Your best bet is to have a coat of sealant on your paint , top that with a wax after 24 hours, then wipe off the droppings as fast as possible with a quick detailer.
Today's Daily special (August 21, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Aug 22, 2009 | 02:26 PM
  #365
Detailed Image
Today's Daily special (August 22, 2009) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.49!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old Aug 25, 2009 | 09:25 AM
  #366
Detailed Image
Today's Daily special (August 25, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
  • Designed to remove a majority of imperfections in the clear coat
  • Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old Aug 27, 2009 | 08:11 AM
  #367
Detailed Image
Today's Daily special (August 27, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Old Aug 28, 2009 | 10:36 AM
  #368
Detailed Image
Today's Daily special (August 28, 2009) is Optimum (OPT) Metal Polish.
Regular Price for 8 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $32.49. Today's price is $24.37!
  • Polish your metal to a high level of depth and gloss with the Optimum Metal Polish
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Most commonly used on wheels, exhaust tips, interior and exterior metal and chrome trim
Old Aug 30, 2009 | 08:52 AM
  #369
Detailed Image
Today's Daily special (August 30, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • We recommend applying a carnauba wax on top of Red Moose Glaze
  • To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Remove Red Moose Glaze with a quality microfiber towel
Old Sep 1, 2009 | 01:25 PM
  #370
Detailed Image
Today's Daily special (September 1, 2009) is Poorboy's World Trim Restorer.
  • Restores faded, neglected trim that has been over exposed to the elements
  • Works best on rubber, vinyl and plastic trim
  • Apply thicker for some gloss or buff dry to desired matte finish
  • For maximum results, prep the surface you plan on restoring with a degreaser like Total Auto Wash
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old Sep 3, 2009 | 09:50 AM
  #371
Detailed Image
Today's Daily special (September 3, 2009) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $5.24!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Old Sep 5, 2009 | 04:06 PM
  #372
Detailed Image
Today's Daily special (September 5, 2009) is Chemical Guys Hose Free Eco Wash.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Old Sep 5, 2009 | 06:13 PM
  #373
xlack's Avatar
xlack
^ is this the same as ONR? I need to get one..
Old Sep 6, 2009 | 12:30 PM
  #374
Detailed Image
Similar product, but not the same as ONR. They are both designed to be rinseless washes. ONR is more of the standard in the industry for that process, the CG version is much newer to the market, so not as much feedback / reviews on it.
Today's Daily special (September 6, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Old Sep 7, 2009 | 12:24 PM
  #375
Detailed Image
Today's Daily special (September 7, 2009) is Chemical Guys Wheel & Rim Citrus Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.74!
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
