Save ~30% or more EVERYDAY at DetailedImage.com!
Auto Detailing Expert
Today's Daily special (September 11, 2009) is Poorboy's World Spray & Gloss (S&G).
Regular Price for 16 oz is $8.99. Today's price is $6.74!
Regular Price for 32 oz is $14.99. Today's price is $11.24!
- Best used after a wash to increase the depth and gloss of any color paint
- Helps extend the protection of sealants and waxes
- Easy to apply and remove without streaking when applied correctly
- Not only works well on paint, but glass, chrome and other areas of your vehicle.
- Best applied with a plush microfiber towel to minimize any micro-marring in the paint
- For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (September 12, 2009) is Menzerna High Gloss Acrylic Shield (HGAS).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $27.99. Today's price is $21.26!
- An outstanding spray on sealant that enhances depth and gloss and extends your paints protection
- Specifically formulated to work best with Menzerna FMJ paint sealant
- Most commonly used after washing and drying your vehicle as a maintenance product
Today's Daily special (September 16, 2009) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.74!
- Enhance the gloss and depth of any color paint, while hiding minor imperfections
- Properly preps your paints surface for sealing with the acrylic based glaze
- Easy to apply and remove when applied properly, which is as thin as possible
- Best applied with a foam applicator pad and removed with a microfiber towel
- When using a buffer, best applied with a black finishing pad
Today's Daily special (September 17, 2009) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $6.05!
- Thickest, softest, most plush towel we carry.
- Over 3x thicker than regular microfiber towels.
- Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Today's Daily special (September 18, 2009) is Dodo Juice Orange Crush Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
- A Dodo Juice soft carnauba wax designed to work exceptionally well on warmer colored vehicles
- Extremely easy to apply and remove, especially when applied in thin layers
- Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
- Can be applied with a foam applicator pad or literally with your bare hands
- Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
- Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (September 22, 2009) is Chemical Guys MetalWax - Ultra Fine Metal Polish & Protection.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
- Restore your metal surfaces to a brilliant shine and protect the finish all in one step
- Ideal for polishing wheels, metal and chrome trim, interior metal trim and more
- We recommend using a foam applicator pad for application
Today's Daily special (September 23, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
- Remove embedded surface contamination that does not come off during the washing process
- Medium grade bars will remove contamination quickly, however it may result in micro-marring
- Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
- Helps you get the most out of any step you perform after using the clay bar
- Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
- We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Today's Daily special (September 25, 2009) is Menzerna Super Intensive Polish PO83.
Regular Price for 32 oz is $44.99. Today's price is $33.74!
- Our best medium cutting polish that is known to remove moderate imperfections in the clear coat
- Most noted for its ability to cut well, good work time, easy removal process and great finish
- On lighter colored vehicles, it is not always necessary to follow up with a finer polish
- On darker colored vehicles, we recommend following up with a finer polish, such as PO106FF
- Most commonly applied with an orange light cutting pad when using a buffer
Today's Daily special (September 26, 2009) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 128 oz is $24.99. Today's price is $18.74!
- An outstanding clay bar lubricant formulated to work specifically with your clay bar
- Can also be used as a quick detailer to remove a light dusting along
- Works great with the Chemical Guys Fine Grade Clay Bar
Today's Daily special (September 28, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
- One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
- ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
- All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
- Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Today's Daily special (September 29, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
- One of the most durable hoses available with the thick 8 ply construction
- Minimize kinks that slow down water flow
- Full LIFETIME Replacement from Gilmour ensures complete satisfaction
Today's Daily special (September 30, 2009) is Clear Kote Quik Shine (QS).
Regular Price for 32 oz is $16.99. Today's price is $12.74!
- An amazing quick detailer that not only enhances the gloss and depth but also cleans the paint
- Ideal for removing a coating of light dusting on your paint or for boosting gloss after a wash
- Works great as a clay bar lubricant
- Use a plush microfiber towel to minimize adding imperfections and to prevent streaking
Today's Daily special (October 1, 2009) is Optimum (OPT) Power Clean.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
- A versatile degreaser that can be used on a wide variety of surfaces
- Powerful concentrated formula can be diluted up to a 3:1 ratio for even more value
- Perfect for degreasing tires, wheel wells, engine bays, stubborn contamination and to clean carpets
Today's Daily special (October 3, 2009) is Dodo Juice Hard Candy Hard Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
- A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
- Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
- Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (October 4, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
- Our most cutting pad option, however, due to the wool strands, not as much heat is generated
- Works best on high powered buffers, for fast, effective paint correction
- Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
- We recommend caring for your pads with Snappy Clean Pad Cleaner
