Save ~30% or more EVERYDAY at DetailedImage.com!
Auto Detailing Expert
Today's Daily special (October 5, 2009) is Chemical Guys Simply Leather.
Regular Price for 16 oz is $8.99. Today's price is $6.74!
- Fresh leather smell
- Spray on fabrics or wipe on interior
- Eliminates bad smells by breaking down odor causing bacteria
Today's Daily special (October 8, 2009) is Klasse High Gloss Sealant Glaze (HGSG).
Regular Price for 500 ml is $20.99. Today's price is $15.96!
Regular Price for 1000 ml is $27.99. Today's price is $21.28!
- One of our longest lasting sealants that looks best after multiple coats
- Can be finicky to remove, so we recommend wiping on and wiping off, working in small sections
- Apply with a foam applicator pad and remove with a quality microfiber towel
- Properly prep the paint with Klasse All In One chemical polish
Today's Daily special (October 9, 2009) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.87!
- Our softest and plushest foam applicator pad that has two distinct sides to apply products with
- Most commonly used for applying last step products (LSPs), such as sealants and waxes
Today's Daily special (October 10, 2009) is Chemical Guys Bare Bones Undercarriage Spray.
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 128 oz is $32.99. Today's price is $25.18!
- One of our best trim dressings that brings out a beautiful black factory finish
- Ideal for wheel wells, under carriage, engine bay and any other dark trim pieces
- To avoid over spray, we recommend misting Bare Bones into a towel, then wiping the trim piece
Today's Daily special (October 11, 2009) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.82!
Regular Price for 32 oz is $49.99. Today's price is $37.49!
Regular Price for 128 oz is $149.99. Today's price is $123.00!
- Our best selling finishing polish that removes light imperfections and lots of depth and gloss
- Easy to work with, with long work times and easy removal when properly broken down
- Most commonly applied with a white polishing pad for a great combination of cut and gloss
- Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Today's Daily special (October 14, 2009) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $29.99. Today's price is $22.69!
- Detailed Image's best leather care product to restore neglected, faded, hardened leather
- Restores oils and proteins that are naturally found in leather for a soft and supple feel
- Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
- Using a hair drier to heat up the leather surface allows for maximum penetration and best results
- Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
- Must be removed by following up with Leatherique Prestine Clean
Today's Daily special (October 15, 2009) is Menzerna Power Gloss.
Regular Price for 16 oz is $18.99. Today's price is $14.24!
- One of our most aggressive compounds we have to offer, allowing for deep paint correction
- Most commonly used on a yellow cutting pad or purple foamed wool pad
- Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Today's Daily special (October 18, 2009) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $39.99. Today's price is $29.99!
- When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
- Works best after correcting paint imperfections with more aggressive polishes
- Most commonly applied with a black or blue finishing pad when used on a buffer
Today's Daily special (October 19, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
- One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
- ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
- All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
- Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Today's Daily special (October 20, 2009) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
- Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
- Remove embedded surface contamination that does not come off during the washing process
- Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
- Helps you get the most out of any step you perform after using the clay bar
- Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
- We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Today's Daily special (October 21, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
- A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
- Also can be used to apply a paint cleaner, glaze or sealant
- Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (October 22, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.24!
- Properly preps your paints surface for applying a sealant or wax to your paint
- Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
- Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (October 25, 2009) is Chemical Guys Window Clean.
Regular Price for 16 oz is $5.99. Today's price is $4.49!
- A tint safe window cleaner that cuts through grime and leaves windows streak free
- Best applied with a microfiber towel and followed up with a glass microfiber towel
Today's Daily special (October 26, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
- Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
- Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
- Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
- For easy dilution and usability, we recommend a 22 oz spray bottle
- Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (October 27, 2009) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
- An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
- Restores and leaves behind a pleasant leather scent
- Easy to apply and remove, while leaving behind a like new matte finish
- Also works well on vinyl and rubber surfaces throughout the vehicle and home
- Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
