Advice on painting or wrapping intakes
Old Mar 7, 2022 | 01:29 PM
swaybar's Avatar
swaybar
Hello , I got a takeda cae for my g37x sedan , I originally wanted to powdercoat the pipe , but im thinking about wrapping them with 3m vinyl. Do you think it will work ? Considering the engine bay heat and stuff , will the vinyl wrap hold up to the heat ?
I welcome any advice on this ,
thank you all
Old Mar 8, 2022 | 06:35 PM
Ponyryd's Avatar
Ponyryd
Should be fine, just imagine how hot a cars finish gets sitting in Arizona sunlight, too hot to touch for sure, but I hope you have a lot of patience if you want it perfect….wrapping a pipe with bends in it is kinda hard.
Old Mar 8, 2022 | 06:37 PM
jesse123456's Avatar
jesse123456
Its actually easy , I did chrome delete and roof wrap all by myself , so this.should be easier
Old Mar 8, 2022 | 06:41 PM
Ponyryd's Avatar
Ponyryd
Thats kinda different…I’ve wrapped stuff before, and a lot of things are pretty easy, but an intake tube usually has bends in it, and is hard to get perfect.
Old Mar 8, 2022 | 06:59 PM
stealthee's Avatar
stealthee
Please explain how wrapping a round tube should be easier than wrapping small chrome trim pieces and a relatively flat roof?
Old Mar 8, 2022 | 07:30 PM
2.2Lude's Avatar
2.2Lude
He can correct me if I'm wrong but I think he's referring to the change of angle in the actual tubing not just the round portion of the tube itself. For example the 90 degree angle for long tube intakes that side in-front of the radiator.
Old Mar 23, 2022 | 04:37 PM
spoolin03's Avatar
spoolin03
I've seen the Honda dudes wrapping their pipes with gold wrap. Supposedly deflects the heat away
Old Mar 23, 2022 | 05:46 PM
Ponyryd's Avatar
Ponyryd
I’ve seen that as well, not on Hondas, but G35s and 350zs.
QX4cor
Sep 16, 2011 08:25 AM
needanewride
Oct 19, 2009 02:06 PM
SaMaster14
Aug 25, 2009 10:20 PM
