Y-Pipe Is Rusted, Which Replacement for G37X Sedan?
Old Mar 12, 2021 | 09:39 AM
m3clubracer's Avatar
m3clubracer
This is good news!!
Old Mar 12, 2021 | 11:17 PM
latino914's Avatar
latino914
Originally Posted by m3clubracer
All the ISR Y-pipes I can find are not for an X/AWD. What is the part number you have and where did you get it?
Trust me it fits. Luvin the sound on mine.
Old Mar 16, 2021 | 10:44 AM
ZzBloopzZ's Avatar
ZzBloopzZ
Originally Posted by projectpanda13
i know a lot of sites says it doesn't fit but it will.
I made a video comparing my friend's ISR and Megan Racing y pipes. He's awd and had both on his car.
he has the ISR headers also and ran into a bit of clearance issues with the ISR y pipe. It was touching the chassis on the driverside, but didn't have that problem with the megan racing. he eventually bought a HBP resonated y pipe.
Thanks for sharing! What do you think has better build quality to use with stock mid-pipe and better against salt in harsh winters?
Old Mar 16, 2021 | 11:44 AM
projectpanda13's Avatar
projectpanda13
hard for me to say about which is best for salted winters. I'm not familiar with the grade of metal used. my Hall Built y pipe is 304SS and it seems that Megan Racing is also. I havne't found what the ISR is as it only says stainless. I am not sure if any brand makes a 316SS.
Old Mar 22, 2021 | 10:38 AM
ZzBloopzZ's Avatar
ZzBloopzZ
All,
I have been reading reviews where the Megan Y-Pipe's flex pipe starts leaking or breaking within a year or so, seen numerous complaints about that. It seems my only option is to try to find an newer OEM or ISR? Does the ISR work with the stock mid pipe and cats?
Old Mar 22, 2021 | 10:39 AM
ZzBloopzZ's Avatar
ZzBloopzZ
Where exactly did you order your ISR Y-Pipe from? Do you know if it'll work with stock cats and mid-pipe?
Thanks!
Old Mar 22, 2021 | 10:41 AM
projectpanda13
the ISR is a 3" outlet like most aftermarket y pipes. It'll bolt up up to the stock cats and mid-pipe but may cause the sound to change due to the piping transition.
Old Mar 22, 2021 | 10:45 AM
ZzBloopzZ's Avatar
ZzBloopzZ
Ah, good point. I noticed all after market seems to be 3" for the mid-pipe connection. Maybe just get that matches OEM from eBay and get OEM gaskets. Issue is it seems common for the flex pipe to break/loosen so maybe get a pipe without the flex, any issues with that?
Old Apr 4, 2021 | 01:49 AM
ZzBloopzZ's Avatar
ZzBloopzZ
I'm still looking for a Y-Pipe. Anyone have a link to a Y-Pipe that will 100% fit the G37X (AWD) Sedan along with having the outlet being 2.5" instead of the 3" outlets that most of the after market Y-Pipes have? I've researched the forums and seems many regret the 3" outlet as creates much rasp/drone with their mid-pipes.
Thanks!
Old Apr 5, 2021 | 06:24 AM
The Pope's Avatar
The Pope
@ZzBloopzZ did you see my earlier post? #13
I'm not sure if the Y Pipes are the same between a G37x Sedan and a G37x Coupe, but if they are...... well..... you could have resolved your issue weeks ago.....
Old Apr 19, 2021 | 10:51 PM
RobC7's Avatar
RobC7
Anyone know the size of the inlet and outlet pipe on the OEM y-pipe?
Old May 3, 2021 | 12:57 PM
ZzBloopzZ's Avatar
ZzBloopzZ
In case you still looking for answer, the stock pipe is measured in this video:
Old May 3, 2021 | 04:59 PM
RobC7's Avatar
RobC7
In case you still looking for answer, the stock pipe is measured in this video: https://www.youtube.com/watch?v=egHsIvVV0QI
I'm seeing conflicting numbers online, not sure which source to trust.
Old May 4, 2021 | 09:40 PM
  #29
ZzBloopzZ's Avatar
ZzBloopzZ
Well in the video he measures the piping on camera for the measurements, he is really reputable person. I would trust that the most over a forum post.
Old May 6, 2021 | 12:22 AM
  #30
ZzBloopzZ's Avatar
ZzBloopzZ
Hello Pope,
I'm SO sorry but missed this message somehow. Do you still happen to have the Y-Pipe?
Thanks!
