Test pipes vs long tube headers
Old Dec 24, 2020 | 09:11 AM
BillyTheMan's Avatar
BillyTheMan
I've got kind of a straight pipe set up right now. Cut off at the resonators, sounds great in my opinion, loud as hell. At some I want to get a cat back system but I also want to get rid of the cats. I was wondering which is easier to install, I tried test pipes once and I couldn't get the demon bolts off but I could probably try again if I had to but how hard are long tube headers to install vs messing with the demon bolts? I know long tubes are a lot more expensive than test pipes, there's an exhaust shop near me but they wouldn't touch the test pipes for legal reasons, weird because we don't do emissions testing around here anymore, cops don't seem to mind my straight pipe set up either.
Old Dec 25, 2020 | 03:42 AM
Birdie's Avatar
Birdie
They probably are about the same.If you are trying to save money you can probably remove the exhaust manifold with the cats still in tact as a whole unit. As this is the way the long tube headers would go into place. Then you can break loose the demons bolts outside the car and install the test pipes. Yes it is more work but if you are after saving this is probably the best option. Unless you have the proper extensions, make sure it is a 6 point socket and try again with lots of penetrating oil a few days prior.
Old Dec 25, 2020 | 08:21 AM
RMB5190's Avatar
RMB5190
You can do the best of both worlds...Get 2015+ headers for much cheaper than aftermarket and add test pipes to that set-up.
Old Dec 25, 2020 | 11:25 AM
BillyTheMan
I actually tried removing the headers when I had the test pipes. I broke 2 bolts off the heat shield and decided to stop before I broke anything else. How necessary are the heat shields over the headers? Could I rig up something else if I broke the bolts off? I tried the extensions and I didn't have the leverage to break it loose. I wouldn't mind taking the headers off, that would make it much easier.
Old Dec 25, 2020 | 11:26 AM
BillyTheMan
Would they fit on a 2011? I'm assuming they would if it's the 3.7.
Old Dec 25, 2020 | 12:13 PM
juster's Avatar
juster
Are 2015+ headers better than previous years for any reason?
Thanks
Old Dec 25, 2020 | 05:28 PM
Birdie's Avatar
Birdie
Heat shield bolts are fragile .you can also go with high temp paint to reduce heat or just wrap them. I did both with mine.
Old Dec 26, 2020 | 08:29 AM
RMB5190's Avatar
RMB5190
Something to do with flow characteristics or size. You'd have to look into the specifics but a couple members who have pursued the FULL bolt-on path have said this.
Old Dec 30, 2020 | 01:14 PM
jpowersjr2's Avatar
jpowersjr2
2015+ exhaust manifolds are designed better than previous years and flow better.
Oakenfire
Intake and Exhaust
Jun 23, 2025 08:31 AM
PongSanity
Intake and Exhaust
23
May 18, 2020 09:44 AM
ayman
Intake and Exhaust
20
Feb 14, 2018 01:50 PM
m3clubracer
Intake and Exhaust
Dec 18, 2015 05:29 PM
beers64
Intake and Exhaust
Mar 24, 2015 01:43 PM
