Downstream o2 Sensor Removal
Old Dec 28, 2019 | 02:38 PM
joey11600's Avatar
joey11600
So i recently purchased some test pipes to put onto my 09’ g37 coupe. I managed to put them on and remove the cats, yet i can’t get the o2 sensors out of them and put them onto the test pipes. I went to the store to get a o2 sensor remover socket and it just kept slipping based on how tight it is into the cats. I need help on what i should do to get them out. I even ordered some cheap o2 sensors just to put in my car for now. But if i can get the original ones out, i’d rather do that. I’m doing this on my own and i’m new to learning cars, so can anyone give me ideas?
Old Dec 28, 2019 | 02:52 PM
NealP's Avatar
NealP
Sounds like you’d have to use something like pbblaster, liquid wrench, or heat to get it out but you’d probably end up damaging the sensor. Also, if it’s already stripped you may not want to reuse them anyway so you’re better off replacing them. You can bring it to a shop to see if they can get it out for you. Good luck.
Old Dec 29, 2019 | 12:51 PM
SkysG37's Avatar
SkysG37
There are 02 emulators out there...
Just just make sure you get the ones that aren't simply resistors, as the ECM it's looking for a consistent signal form
Old Dec 30, 2019 | 01:54 PM
Surfnazi's Avatar
Surfnazi
They have a slip socket that has a cut on the side so wire wont interfere with removing it
Old Dec 30, 2019 | 02:21 PM
NealP's Avatar
NealP
I'm pretty sure that's what he did ^
Old Dec 30, 2019 | 02:26 PM
ILM-NC G37S's Avatar
ILM-NC G37S
I always use(d) a proper sized box wrench or a pipe wrench. Those "slip on" sockets are nothing but pieces of absolute crap- never had one work yet.
Randy Johnson
Intake and Exhaust
Jun 6, 2018 02:04 PM
Jonesmeister11
Intake and Exhaust
May 16, 2017 01:48 PM
OMG35S
Jun 21, 2011 04:47 PM
chucky
Intake and Exhaust
Feb 7, 2011 01:48 PM
Rapture37
General Tech Questions
May 14, 2009 02:00 PM
