Can anyone recommend a site to buy a cat converter?
#31
However, since they did the install, checking for leaks should be on them. They might simply not want to work on your car anymore. That happens.
#32
If you plan on replacing the sensor (I would hold off on this) than get the oem part # and check ebay. Call your infiniti parts department and get the part #.
they can be had for $120 or so on amazon and ebay.
Mr.Jones (11-17-2018)
#33
I guess maybe it's just me, I had FI Resonated, Z1, and Berks and all of them threw lights with in 10K miles. The latest version of the Z1 Had J extensions but still got a CEL? but that my be because they are only 100 CEL .
John you don't count man-- how man miles you drive in three years 5k LOL , JK man!!
And remember most tuners will automatically turn these off. Not saying the guys that state "never" have tunes, just putting that out there.
#34
#35
2000? Woaah that’s too much
I was wondering if any of you could help me find a website to buy them? The shop said I needed both sides. It's a 2012 g37xs sedan.
I don't need fancy ones, I'm not an enthusiast, there's 92k miles on the car, the cheaper the better.
Some local shops wants to charge me around 2 grand for the pair and install, which I cannot afford.
I appreciate it guys.
edit: https://www.ebay.com/itm/263803447023 $260 for a new pair on ebay? Will that work?
#36
Here what occured....
CEL just came on tonight Assuming I get the same code when I take it to the parts store tomorrow, what do you guys recommend I should do?
-possibly get new o2 sensors?
-have them clear the code, then if it comes back just ignore it?
-will the care still be safe to drive / will I be causing any harm to it? Assuming it's the same code.
#37
Drove the car around for 20 mins today, noticed I had noticeable white-ish smoke coming from the back so I stopped at a gas station to investigate. As soon as I stopped the CEL came back on. I took a small video of the exaust and put it on youtube for you guys if anyone has any opinions. Bear in mind, it is 25 degrees outside right now, but It was noticeable when I started it in the 45 degree or so garage.
also noticed a small drip coming from exaust
I think the best option is to take it back to the shop who did the work on the cat, tomorrow. Or should I wait and order some thicker z1 gaskets first?
Other thoughts? Thanks guys
#38
That's normal.... you said it's 25 degrees outside. The exhaust gases coming out your tail pipe is hot.
what happens when you exhale out of your mouth on a cold day? Same thing...
#39
Every exhaust will drip water under the right conditions. It's just water. If it were gasoline, that's a problem, but it's just water and water vapor. You're being hyper-sensitive to seeing ghosts where there are none.
And now you've got a CEL because of your new high-flow cats, which you should have suspected but still seem surprised about anyway. Odds are your car is running fine, and this won't be an issue until you need to get inspected. You've got between now and then to figure this out. Go with the obvious, and get sensor extensions on those cats. Have the shop look for leaks while that's happening.
#40
The code p2a00 is saying upstream sensor.
#42
i seen you’re original thread on the catalytic converters p0420 codes. my car is not wanting to move from a deadstop, and if i get up to 40+ the car will just rev up and not really go any faster ? is this the issues you were having ? i’m super stressed about this and it would relieve me so much to know i just gotta replace the cat
