Help FI RHFC => a lot louder ??
Old Jul 26, 2018 | 05:44 AM
Kaighal's Avatar
Kaighal
Question FI RHFC => a lot louder ??
Hello,
This is a follow-up topic after having asked for your help here.
I solved my issue with a MotorDyne XYZ-pipe with its resonator module, while keeping the GT-Haus midpipe and muffler.
But, when I ordered the XYZ-pipe (through Z1 MotorSports, I also purchased Fast Intentions' Resonated High-Flow Cats (RHFC) because, "why not". I thought that extra resonators on the cats would help too...
Silly me !
I had the RHFC installed yesterday and the sound is now a LOT louder. The volume is insane (in a bad way) in the 3-4K RPM range and it has become slightly raspy again. It is louder than when I had the GT-Haus Y-pipe (but less raspy).
It is a surprise, because on their site, Fast Intentions says this :
This application is recommended for the enthusiast who wants to remove their OEM catalytic converters, but keep the sound level to a minimum. This is our quietest option available.
I had also checked out user reviews and people seemed to say that the tone was a bit deeper but the overall volume was identical or had barely increased.
But then again, the GT-Haus muffler is what it is, and might be the culprit here. It produces a beautiful note but also seems to amplify the volume to extreme levels.
So the questions are : is this due to the cats being new, will the sound volume go down to something close to what I had with OEM cats ? Or is it normal and here to stay (unless I put the OEM cats back, which I will probably do in this case) ?
Once again, thanks in advance
Old Jul 26, 2018 | 12:37 PM
ANMVQ's Avatar
ANMVQ
^^ Funny I had FI's RHFC on my 09 and also and thought they were louder than the Z1's I previously had installed. I went back to Z1's and sold the FI RHFC's. They'll get louder as they break in :/
I have Z1's again on my Q50.
Old Aug 14, 2018 | 11:54 AM
Kaighal's Avatar
Kaighal
Bump, does anyone have a clue about what might be wrong ? I suspect something from the install that the local garage might have missed and I would need directions for them.
Even highway-cruising speed is completely unbearable and I am quite sure that this should NOT be the case.
Please help me !
Old Aug 14, 2018 | 02:26 PM
6MT>7AT's Avatar
6MT>7AT
Certainly doesn't seem like anything is wrong unless you have an exhaust leak but I doubt that's the case. RHFC is the quietest option when replacing OEM cats so if you really don't like it then you should probably put the stock ones back on. I don't really see the point in replacing them unless you actually plan on having the car tuned. I would argue that most exhausts sound better with stock cats but that's just my opinion. If you do decide to remove them let me know they're the last thing I want before I get my car tuned.
saltfish
Intake and Exhaust
35
Nov 23, 2009 01:39 PM
yacoub
Intake and Exhaust
33
Jun 1, 2009 06:53 AM
veejayy2
20
Apr 19, 2009 07:40 PM
Dimitry6
Intake and Exhaust
18
Feb 25, 2009 05:37 PM
DPE_G35
21
Jan 5, 2009 01:41 AM
