aFe Silver Bullet Throttle Body Spacers
Old May 27, 2021 | 08:08 AM
SonicVQ's Avatar
SonicVQ
Originally Posted by Dzionassi
I made them.
PETG, ABS or something else?
Old May 27, 2021 | 07:25 PM
Dzionassi's Avatar
Dzionassi
I think it was PLA. Nylon would be better.
Old May 27, 2021 | 08:36 PM
iCrap's Avatar
iCrap
Did you design them? If so would you be willing to share the file? I'd like to try it out.
Old May 27, 2021 | 09:59 PM
kRAM's Avatar
kRAM
How is the PLA holding up? I thought PLA would deform from engine temps.
Old May 27, 2021 | 10:41 PM
infiniticarplug's Avatar
infiniticarplug
Left ks obviously the new coupler that i got. Pretty much double the size.
Think it finally has a nice amount of surface area. Definitely feel much more confident in the fit then before.
Old May 27, 2021 | 10:54 PM
Dzionassi's Avatar
Dzionassi
Sure (send me you email), you just need to add cardboard gasket from TB side or just rubber/silicone "o" ring
Old May 27, 2021 | 10:57 PM
Dzionassi's Avatar
Dzionassi
Like it is seen in the pic, holding up just fine. I did have to re tighten bolts 2 times. (O ring getting crushed)
Old May 27, 2021 | 11:10 PM
iCrap's Avatar
iCrap
I sent you a PM. Also, I need to get longer screws i would imagine too right? What length is needed?
Old May 27, 2021 | 11:53 PM
Dzionassi's Avatar
Dzionassi
I used:
Amazon Amazon
Old May 28, 2021 | 08:36 AM
SonicVQ's Avatar
SonicVQ
Keep an eye on them... PLA will slowly deform (compress in this case) when it is above 60C / 140F AND they will get up to 100C / 212F since they are heated by the engine coolant.
Old May 28, 2021 | 09:57 AM
iCrap's Avatar
iCrap
Yeah, im shocked you haven't seen any issues with the PLA. I'm going to try mine with ABS.
Old May 28, 2021 | 09:05 PM
Dzionassi's Avatar
Dzionassi
Yeah, I know. I have set of aluminum ones. Just did not have chance to replace them...
Old May 29, 2021 | 12:37 AM
iCrap's Avatar
iCrap
I have a CNC mill also, and I was thinking about making them from alu if they work well. For now, i'll just do ABS. I changed the design a tiny bit and added a little indent for the o-ring
Also, i noticed the AFE ones have that spiral thing on the inside, i dunno if that helps at all though. I would guess... no?
Old May 29, 2021 | 12:49 PM
  #29
Dzionassi's Avatar
Dzionassi
I think spiral could work in front of intake, right after velocity stack, but after TB I would say no.
Old May 29, 2021 | 01:05 PM
  #30
iCrap's Avatar
iCrap
Thats what I was thinking. maybe they just added that for the looks
