installing test pipe is crazy hard....
Old Dec 11, 2017 | 08:33 PM
ljjhw's Avatar
ljjhw
today i got my non resonated test pipe , and try to install .. but it is almost impossible to pull bolt out...
have any one try this ?
the bolt that connect y pipe and cat , it got stripped out so i try to use angel grinder next time... the bolt in the top dont wanna move out too...
i m not sure is this possible to work in home or i should bring to shop..
Old Dec 11, 2017 | 08:54 PM
PNW_IPL's Avatar
PNW_IPL
bro.
you think the y pipe is hard wait til you get to the DEMON bolts.
the oem y pipe has studs that are pressed in. Only the nut comes off so cut those off if stripped itll come off.
STOP BEFORE going any further soak all the bolts with PB BLAST OR EQUIVALENT PENETRATION OIL.
then let sit for couple hours a day is better then try again.
take a pic so i can better help you
Old Dec 11, 2017 | 08:58 PM
ljjhw's Avatar
ljjhw
Originally Posted by PNW_IPL
bro.
Thank you for fast reply ! , i try bottom bolt but i think i make 3 other bolt round... so the ratchet doesn't work..
also put PB blaster but still didn't work... h aha
Old Dec 11, 2017 | 09:01 PM
PNW_IPL's Avatar
PNW_IPL
Are you using the correct size socket with 6 point?
or you using 12 points?
Old Dec 11, 2017 | 09:25 PM
qmantran's Avatar
qmantran
If you rounded out 1 bolt, what made you think it would be a good idea to keep rounding off the other bolts? So they would match?
You should only be using 6-point sockets.
Old Dec 11, 2017 | 09:26 PM
PNW_IPL's Avatar
PNW_IPL
Old Dec 11, 2017 | 09:39 PM
iCrap's Avatar
iCrap
lol taking off the y pipe is the worst. I had to angle grind it off and put new bolts. Have fun!
Old Dec 11, 2017 | 10:31 PM
Here~ and be SURE to use the 50:50 Acetone ATF mix for bolt soaking, much better than most any other rust breaker.
https://www.myg37.com/forums/g37-sed...y-be-atch.html
future62
Intake and Exhaust
Aug 7, 2017 11:16 PM
Kevalteam
Jun 16, 2014 10:50 AM
Yuweezy
MODDING 411
Jun 15, 2014 01:17 AM
Damn Dirty Ape
Oct 22, 2012 08:02 AM
LAZY TURBO
Intake and Exhaust
65
Apr 20, 2008 08:11 PM
