Nissan designed a great intake system (K&N filter dyno vid)
Old Jul 29, 2017 | 10:55 AM
future62's Avatar
future62
Look at the gains beyond 6.5K! I was trying to decide what intake to buy... they are all so expensive. Looks like all I will need are the K&N drop ins + resonator delete + hood insulation delete. I was just hoping for more sound with the same power; this is even better....
Old Jul 29, 2017 | 01:58 PM
Victory's Avatar
Victory
Yep. Who would have thought a team of engineers with a multi-million dollar R&D budget could design an efficient intake.
Old Jul 30, 2017 | 01:36 AM
Ape Factory's Avatar
Ape Factory
Man it's amazing how the car's hp fall off a cliff at 7K rpm. Even with really poor a/f ratios, my car kept pulling to redline. The Stillen exhaust should help in that department.
Are you monitoring a/f ratios?
One problem with the K&N's is MAF contamination and the fact they don't filter as well as stock. Not sure if anyone makes one but I'd try a high performance dry panel filter.
Old Jul 30, 2017 | 10:25 AM
Victory's Avatar
Victory
R2C makes a dry panel filter. I have them in my sedan. About $100 for the set. Way easier to clean than oiled gauze too.
Old Jul 31, 2017 | 04:34 AM
future62's Avatar
future62
Thinking about it after changing my filter, it's possible the gains could have just come from the old filter being dirty.
Old Jul 31, 2017 | 09:52 AM
Ape Factory
How many miles on the filters? I had an R2C intake kit, their filters are very good. Maybe grab a pair of their panel filters and test those back to back with the K&N.
Old Aug 9, 2017 | 08:10 PM
SonicVQ's Avatar
SonicVQ
With the factory tune on the sport sedan the throttle bodies start to close to about 60% after 7100 - 7300 RPM. This is the "soft rev limiter" Fuel cut off is 7600 RPM.
I suspect the coupe or IPL may be different.
Old Aug 9, 2017 | 08:15 PM
kroy's Avatar
kroy
Would there be a difference between coupe and sedan?
I have an IPL. Red is my dyno run with stock tune and K&N typhoon.
I noticed my rev limited cut in more like 7400. In real world practice though, I need to shift right after passing 7300 or else I won't shift in time and will hit the soft wall.
Blue curve. not sure, but i think it's 7700 with soft limit.
Green has rev limit set to 7700 with no gradual soft rev limit.
