Stillen Gen3 vs. Injen Cold Air Intake
Old Aug 8, 2016 | 10:01 PM
airken's Avatar
airken
Anyone know which ones is better?
Seems like Stillen's are a lot easier to install since it sits in front of the radiator, whereas the Injen ones goes down to behind the fog lights/in front of the wheel wells. Also, Stillen's are higher up, so less likely to get water inside.
In terms of HP gained at the wheels, they're pretty comparable.
If it is just the difference in installation, I will probably go with the Stillen's.
Any opinions? Suggestions? Comments?
Old Aug 9, 2016 | 09:56 AM
PNW_IPL's Avatar
PNW_IPL
Injens require you to swap wiper fluid tanks and if sensor is not transfered no dummy light will work on dash. I think stillen design yield a bit more hp since it's drawing cool air behind grill.
Old Aug 9, 2016 | 09:57 AM
PNW_IPL's Avatar
PNW_IPL
Side note not sure if injen require cutting the radiator support but stillen does. To avoid go with Takeda instead
Old Aug 9, 2016 | 11:09 AM
Ricio1991's Avatar
Ricio1991
Stillen for sure the quality is far better! The Stillen will need you to dremel the core support for the intakes to sit on. I would recommend taking it to a performance shop unless your are really good at installation it's not just plug and play
Old Sep 9, 2016 | 04:17 PM
q60scash's Avatar
q60scash
stillen has better gains and its in a better location, since its infront of the radiator u get that colder air lol but ya that whole washer fluid bs looks like a hassle
Old Sep 9, 2016 | 04:25 PM
2011-G's Avatar
2011-G
I would definitely go with stillen just because of the filters location
Had a g35 with AEM cold air intake that was right infront of the wheel wells. damn that was scary but it sounded awesome!!!!
Old Sep 14, 2016 | 01:20 PM
bPChaos's Avatar
bPChaos
You don't need to dremel it, just get a small plastic saw and go at it. You can make two parallel cuts, score the plastic, and it just snaps off.
Something like this works: https://www.amazon.com/Xacto-X75300-...rds=x-acto+saw
I did it last night, and the core support was one of the easier bits of the install.
Old Sep 15, 2016 | 12:22 PM
Eyzclosed's Avatar
Eyzclosed
i would go with stillen
Old Oct 16, 2016 | 08:41 AM
PongSanity's Avatar
PongSanity
Admin Tuning 3 inch intakes or z1 intakes w/ velocity stack.
Old Oct 17, 2016 | 11:25 PM
Kris9884's Avatar
Kris9884
I realize the OP is probably not looking anymore but for the searchers, I went against the grain and got Injens CAI. The air flows into the front grill just as cold and freely as the fog light spots with the faux grills removed so comparing filter placement between the two brands is a wash. I solely went with Injen so I could put my oil, PS and trans coolers in the front grill instead of the SG3 filters and still have some flow for the radiator left, not to mention it was almost $200 cheaper. There's just too many variables with getting a dyno to REALLY say which is best when there are tons of peoples threads around here, 6MT and My370z showing numbers all over the place. Its a total toss up, some get 16hp while others get 3hp... I think as long as you're getting the filters out of the engine bay it doesn't matter which brand you grab.
Brown324
Nov 7, 2015 08:39 PM
Redfire32
MODDING 411
Jun 9, 2015 03:31 PM
Ra_
Aug 26, 2012 06:53 PM
MJD41985
MODDING 411
May 1, 2012 02:21 PM
Pms1212
Intake and Exhaust
22
Sep 23, 2008 06:12 PM
