Top Speed (Pro-1) Headers
Old Dec 18, 2015 | 02:18 PM
ANMVQ's Avatar
ANMVQ
So I'll ask anyone here use these? Seem like the G35,350Z guys use them and had good things to say about them. We know their cat back is a good set up blnewt runs it,
So I might swings at these, at lease the drivers primary wont hit the motor mount like the momentum headers did :/
CZP sells these also
http://www.amazon.com/VQ37VHR-Top-Sp...d/dp/B012C5U1U
Old Dec 18, 2015 | 08:01 PM
Upscale Speed's Avatar
Upscale Speed
Not giving up, that's awesome man. I will keep everyone posted on my Stillen header install. The shop was slammed and thats the real reason they couldn't get to it. I read between the lines clearly. Anyways there is a solution for us. The stock headers fit in there no problem and the aftermarket ones are bigger, but not a ton bigger. It's the routing of the tubes that creates an issue. The Stillens look like they will fit and so do those Top Speed ones.
Old Dec 18, 2015 | 10:04 PM
Baby Jumpman's Avatar
Baby Jumpman
I know someone who has stillen headers on his awd sedan so they will fit for sure. Will ask him if the shop had to do anything to make it fit or was it strictly plug and play so to speak.
Old Dec 20, 2015 | 12:47 PM
Upscale Speed
Let us know man.
Old Dec 20, 2015 | 09:47 PM
Baby Jumpman
Old Dec 21, 2015 | 05:18 PM
Upscale Speed
I should have my car back tomorrow got update today and initial report was that they fit without modification.
Old Dec 22, 2015 | 04:29 PM
Upscale Speed
Stillen headers installed on my car today, they fit without modification.
Old Dec 26, 2015 | 06:19 PM
ANMVQ's Avatar
ANMVQ
SO bought Stillens, Just sent the $$ today to Kyle @import parts pro. Vendor FTW great guy have used them a few times now.
Old Dec 26, 2015 | 08:37 PM
ColumbiaSkinny's Avatar
ColumbiaSkinny
Do you know what the diameter in piping difference is between the Stillen and the stockies? I'm sure it's larger but exactly how much larger. Congrats on the purchase and good luck....
Old Dec 27, 2015 | 02:33 PM
ANMVQ's Avatar
ANMVQ
I don't remember of the top of my head but there is thread floating around with the measurements. The collector is MUCH larger. Thanx man I'll be measuring things also
Old Jun 10, 2016 | 02:56 PM
Jmeg37x's Avatar
Jmeg37x
Stillen header
2010 g37x I wanna buy the stillen header would I need to modify it or would they fit with no problems
Old Jun 17, 2016 | 08:11 AM
ANMVQ's Avatar
ANMVQ
There would be no modifications need at all
Old Jun 17, 2016 | 09:51 AM
astat4's Avatar
astat4
I installed g35/350 Megan style long tube headers on my g37 coupe.. only problem I had was that the bottom tube was actually sitting on the car frame.. so now my car vibrates a bit.
I had to unbolt the engine mounts to raise the car and get the long tubes in and disconnected the steering knuckles/shaft. Just make sure you mark it. It's 2 12mm bolts. ... shorties might be a different story.
Old Jun 17, 2016 | 10:03 AM
zer099's Avatar
zer099
I'm in a X as well, went with Stillen for the headers as it pretty much the only confirmed fitting headers for us AWD guys. My advice is to do some port and polish work on the collectors if you can before the install. I spent a solid day cleaning up the pooled welds inside the collectors and shaping them down to good free-flowing setup and then ported out the flange to match the piping. Did it do anything, no clue as I didn't get a before dyno and after, but I promise it didn't hurt.
Topher9425
Mar 6, 2016 08:40 AM
SelbyL
Dec 21, 2015 08:01 PM
jchart1000
Dec 20, 2015 04:57 AM
m3clubracer
Intake and Exhaust
Dec 18, 2015 05:29 PM
*ICE*
Dec 18, 2015 01:06 AM
