Gen3 hole
Old Feb 18, 2015 | 02:20 PM
ToXIc's Avatar
ToXIc
Gen3 hole
So i have a Stillen Gen3 coming in and like most of you I'm curious about the hole to be cut.. so i've googleed around and all i saw was some janky butchered holes..
It is that hard to cut? i was looking for an example of a minimal cut. Anyone else out there OCD?
Old Feb 18, 2015 | 02:32 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
I haven't installed the Stillen intake, but I will offer my advice from completing similar jobs. I recommend holding up the pipe where it needs to go and drawing an outline of what needs to be cut with a silver sharpie. I would then use a Dremel with a cut off wheel attachment. To clean up the cut you can put the grinding/sanding wheel attachment on the Dremel to smooth it out. You can also use this attachment to slightly widen the hole until the pipe fits through nicely.
That's the method I used to install these ballasts into this headlight housing:
Old Feb 18, 2015 | 02:39 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
they are not hard to cut if you take off the bumper..but seeing that you never see the holes I could care less what they look like. and don't forget to wrap your a/c lines so the intake doesn't rub a hole in them
Old Feb 18, 2015 | 02:59 PM
ToXIc's Avatar
ToXIc
been thinking about doing something along those lines.. thx..
oh i came across a pic of that.. while searching.. i was like ummmmm....
Victory
17
Oct 27, 2022 03:45 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
tkuntz
Oct 12, 2015 01:17 AM
G37X GraSdadow
Sep 2, 2015 04:09 AM
