Berk Testpipes = check engine light :(
Old Jul 29, 2014 | 09:17 PM
604's Avatar
604
Just got my Testpipes installed
I love the sound.
Only negative is the engine light came on and won't go off. (Code is cat converters surprise surprise)
I know the Berk website said the defouler design protected against this but was more effective on G35s.
Has anybody else had success getting rid of it?
Thnx
Old Jul 29, 2014 | 10:18 PM
Reset and wait for it to cycle. Sometimes it triggers for people after the install. At least, that's the opinion I've seen here. My FI cats worked just fine from day one, although not the same thing as your test pipes, I get that. G'luck.
Old Jul 30, 2014 | 08:35 AM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Berk + CEL light = Shocker
Old Jul 30, 2014 | 10:40 PM
604's Avatar
604
It is a little when the claim to fame is "Mechanical CEL fix included".
They should change the disclaimer to *will not work on 07+ HR motors.
Old Jul 30, 2014 | 11:11 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
A bit of 0000 steel wool in the J bung might keep the worst of the **** off the O2 sensor. Try it, and cycle your ECU, see if it comes back.
You should probably get a tune anyways, you can switch off that sensor with uprev
Old Jul 30, 2014 | 11:32 PM
Hollywood619's Avatar
Hollywood619
I'm installing my Berk HFCs next weekend, same issue? Can you guys explain "cycling" the ECU? Also, how much 0000 did you put in your J bung?
Old Jul 31, 2014 | 12:02 AM
TheLocNar's Avatar
TheLocNar
Try some other o2 extenders.
Old Jul 31, 2014 | 07:56 AM
I've heard of that trick. However, can't say as I would ever do it. No way no how.
If the CEL is persistent after clearing a few times, take the car to a decent shop and have an extender welded on.
Old Jul 31, 2014 | 09:15 AM
GoFightNguyen
Because Racecar
I didn't put any in my J-bung, I got a tune and my tuner just switched off those O2 sensors. I imagine it's enough to provide a filter matrix, I wouldn't pack it in there like a pipe.
Cycling the ECU means resetting it using the weird pedal dance.
I had to try 4-5 times before I got it. Resetting your ECU clears the engine codes that are already present, but if the ECU senses the the problem is continuing, then it will turn the light back on. For example, if you don't plug in a MAF sensor in your intake, your car will idle weirdly and you'll get a CEL. If you just plug it in, the light tends to stay. If you reset the ECU, at this point, the problem is fixed and won't come back. However, if you have low oil and reset the ECU, the low oil light will still be on.
Old Jul 31, 2014 | 06:31 PM
604's Avatar
604
Easy Way to Reset ECU without battery disconnect in G37 - YouTube
Thanks, that actually did the trick!!!
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
STownSaint
Aug 29, 2015 09:04 AM
moy92
Aug 20, 2015 08:43 PM
moy92
Aug 19, 2015 05:30 PM
