Takeda CAI whistle
Takeda CAI whistle
Does anyone have a takeda CAI? I know they whistle at high rpms because my friend's does it, does yours do it? I installed mine a couple of months ago and is not doing it. IMO it makes it sound like a turbo kinda, so i want to know if you guys did something to it to make it sound that way.
Some short rams bleed off crankcase pressure when you shut the engine off, that's it. If your buddies car is producing that sound under load, he should check all his connections, because he likely cracked one of the plastic air intake resonators that plumb into the intake with rubber hosing. Ill also bet he's ingesting dust and will see a build up ring on the inside of the rubber coupler on the throttle body. Just my 2 cents, and nope I don't, but they look cooool!
