Port and polish TB's, manifold and lower manifold from IPS Motorsports!
Old Dec 4, 2014 | 06:21 PM
  #91
Synolimit's Avatar
Synolimit
Picssssss
Attached Thumbnails Port and polish TB's, manifold and lower manifold from IPS Motorsports!-image.jpg
Old Dec 4, 2014 | 06:40 PM
  #92
Synolimit's Avatar
Synolimit
Picccssss
Old Dec 5, 2014 | 06:18 PM
  #93
ANMVQ's Avatar
ANMVQ
nice man but does every have that DAMN dip in power at 5500? :/
Old Dec 6, 2014 | 09:21 AM
  #94
Synolimit's Avatar
Synolimit
Huh?
That dips a MAF spike. Why? Idk. Cars with 2 MAF's can be a pain. I did notice the owners MAF pipe is not completely round from the Stillen's T bolt clamps. This is why I hate those. You can't tell how tight or loose to make them. Unless you're running 30 pounds of boost, worm clamps work perfectly.
Old Dec 30, 2014 | 06:46 PM
  #95
Tiny's-G37s's Avatar
Tiny's-G37s
So only a 7 horspower and 5 torque increase with all three installed?
Old Dec 30, 2014 | 08:18 PM
  #96
Glover998's Avatar
Glover998
If you have access to 95 or 98 pump gas you wud get some decent gain from these breathers .. But what happened when u decreased the timing 4d .. Did you lose some power ?!
Old Dec 31, 2014 | 02:18 PM
  #97
Synolimit's Avatar
Synolimit
If you're only looking at peak power yes. There's more increased power at other points in the powerband as high as 11. Till we further test the setup by matching the exhaust to the new bigger intake we won't know the true gains. This is NA power let's not forget! The claims you see from increases from most parts is BS! It's almost impossible to gain good power with no forced induction. Anything you really gain will come as the first mod. After that expect almost nothing. For spots to even get 11 is pretty good at his mod level.
Old Dec 31, 2014 | 02:22 PM
  #98
Synolimit's Avatar
Synolimit
knocking at higher levels will always kill power. We had to decrease timing to make power. The car over all is making about 5-6 degrees less than it should! Based on that we could be making a killing if we figure it out.
Old Dec 31, 2014 | 03:02 PM
  #99
ANMVQ's Avatar
ANMVQ
What are you making timing wise up top before the knocking
Old Jan 1, 2015 | 11:29 PM
  #100
Synolimit's Avatar
Synolimit
no idea. It's at 23 now. Knocks over it.
Old Jan 2, 2015 | 01:09 PM
  #101
ANMVQ's Avatar
ANMVQ
OK cool just curious cause I'm running same timing up top
Old Jan 2, 2015 | 03:29 PM
  #102
Synolimit's Avatar
Synolimit
Because you have cats right? The backed up heat is killing the performance.
Old Jan 2, 2015 | 04:09 PM
  #103
ANMVQ's Avatar
ANMVQ
I have Z1 HFC's.
Old Jan 3, 2015 | 02:29 AM
  #104
Synolimit's Avatar
Synolimit
Sell'em.
Old Jan 3, 2015 | 11:31 AM
  #105
alfredo24pr's Avatar
alfredo24pr
Sell'em.
What do you have? Test pipes?
