trottle bodies
Old Jan 6, 2014 | 09:45 AM
monty2003's Avatar
monty2003
Originally Posted by LexiG37
Don't our throttle bodies fully open and remain fully open when the engine is started? They shouldn't be responsible for a rough idle if they're fully open all the time. The VVEL regulates engine speed, not the throttle bodies. The throttle bodies are simply there as back up when/if the VVEL solenoid fails.
So whether your throttle bodies are filthy or pristine it shouldn't matter.
VVEL provides valve timing and has nothing to do with engine RPM. The throttle body regulates airflow and the MAF and O2 sensors tell the computer how much fuel to add through fuel injection to maintain the best A/F mixture.
If you want to learn how our engines work, read the shop manual. There is an incredible amount of detail there.
Brian
Old Jan 6, 2014 | 10:01 AM
TVPostSound's Avatar
TVPostSound
Brian
Incorrect.
Read the info from the designer:
Quote "VVEL-equipped engines control air amount at intake-valve by the combustion chamber entrance, which enables necessary air to be sent promptly to combustion chamber, resulting in better response."
http://www.nissan-global.com/EN/DOCU...0713VVEL-e.pdf
Old Jan 6, 2014 | 10:34 AM
monty2003's Avatar
monty2003
Incorrect.
I stand corrected. Thanks for posting the info.
Brian
Old Jan 6, 2014 | 11:54 AM
socketz67's Avatar
socketz67
Community Builder
It almost seems that while the VVEL setup is far more complex, it offers alot of opportunity for aftermarket ECU upgrades, but at the cost of a much high barrier to entry.
Old Jan 9, 2014 | 11:54 AM
TVPostSound
UpRev has cracked the VVEL programming, but still dont know what to do with it!!
Old Jan 11, 2014 | 08:40 AM
gsm026's Avatar
gsm026
VVEL is variable intake lift, like BMW's Valvetronic system. Your throttle plates snap open just above idle and your right foot is effectively tied to valve lift.
Not sure how dirty TB's cause rough idle either, but enough people have the issue that I believe it. Cleaning should be an easy DIY.
Old Jan 11, 2014 | 11:25 AM
socketz67's Avatar
socketz67
Community Builder
That's a cool presentation. Thanks for posting the link.
It compliments this article I had read previously that talks about how the engine was built for 1000hp+
Nissan 370Z Review; Engine (VQ37VHR) > 370z.com > 370z.com - Magazine
Since the motor has been out since 2006, I'm still curious as to why the ECU programmers haven't embraced it more openly. Maybe the complexity is a major barrier. I have to agree that the operation is not easy to grasp, especially if you have to unlearn what you already know about cams, valves, intakes, etc. VVEL is like one big control loop.
The new uprev tune thread on here is encouraging.
eljoker
Future Models
19
May 30, 2022 11:48 AM
37
Oct 17, 2020 11:12 AM
SuperMario77
Oct 29, 2015 11:12 AM
arkyv714
Oct 4, 2015 03:44 PM
dedmanchan
Sep 24, 2015 11:25 PM
