R2C Intake - Lessons Learned
Old Sep 2, 2013 | 10:39 AM
Originally Posted by glennp_2012
I was looking at this intake so in your opinion is it worth getting or should I go with the overprice Stillen?
Like I said up front:
Instead of talking about the merits or shortcomings of the R2C kit over other intakes, I thought it might add value to share some observations about fitment and parts.
Stillen sells 3 models, so take the time to do your own research when it comes to choosing a particular design, make & model intake that suits your automotive values. There are a bazillion threads here comparing intakes. This isn't one of them.
That said, you can't go wrong with the Stillen Gen3. Go for it.
Old Sep 2, 2013 | 03:22 PM
brizey's Avatar
brizey
I had to look that up. RRG = Red Rubber Grease. Apparently any silicone grease would work in this case as well.
Good advice, brizey!
Yep. Its made from vegetable based oil. They color it red on purpose as a sort of reminder. I had some rubbing vacuum hoses on my old WRX and used it for that.
Old Sep 4, 2013 | 09:30 PM
JblueG37's Avatar
JblueG37
Don't get me wrong, I love the way this kit looks in the bay...but it seems like so many minor details that have to be tweaked for the price. Or am I just a noob at pricing items for a G37? lol
Old Sep 4, 2013 | 10:11 PM
It seems that most intakes need a bit of help from the owner to get everything just right, and Rochester is a bit more discriminating than your avg. G owner Seems like the R2C is in line w/ other intakes' pricing (and issues).
Old Sep 4, 2013 | 10:45 PM
Thanks, Newt.
I think that every aftermarket modification requires some kind of final customization effort, whether structural or cosmetic. It could be a $3000 set of rims where you customize the center cap, or a 2-cent washer that makes all the difference in fitment on an Intake. Not to put too fine a point on it, but that's what makes the whole idea of modding a car fun.
Old Sep 14, 2013 | 11:20 AM
I was thinking of getting my FSTB powder coated in the same finish as the intake mid-pipes, and wrote to R2C for information on that. Turns out it's not powder-coated at all. It's a multi-step plating process, similar to chrome plating.
Hmm. Wonder where I go with that?
[edit] Currently have emails out to a few local Plating Shops. Maybe I can get these to match. We'll see.
Old Sep 17, 2013 | 09:50 PM
LilRocket's Avatar
LilRocket
I was thinking getting my window trims and my chrome finishes changed to that same black nickle finish as the R2C intake or something of the sort (but darker finish). It would look great for once I get the intake to match. But still thinking about it, I really don't like chrome finish.
Old Sep 17, 2013 | 10:22 PM
After some research and a ton of emails, getting the FSTB plated Black Nickel would be around $200 give or take. That's a lot. So now I'm researching Black Chrome, which is slightly different but still similar and lots more common.
IDK... The whole idea might get shelved.
[edit] shelved for the future, or never.
Old Oct 7, 2013 | 09:42 PM
Bota36's Avatar
Bota36
Alright John...you're the reason I placed my order today. Awesome wright up and I'm looking forward to the install. I ordered the black nickel as well.
Old Oct 7, 2013 | 10:05 PM
MAF Wire Housing
After you've taken the intake apart and re-installed a half-dozen times, you discover access to things that you might not have appreciated before. Like the small coolant return lines in the Air Conditioning system, that actually polish up real nice, like chrome. Seriously, they look fantastic with a little metal polish. Or the bolts on the Power Steering Reservoir bracket, that could easily be replaced with something to match other custom bolts in the engine bay.
Then there's the MAF wiring. It always seemed kind of raw, and sloppy. But it's an easy thing to take what's there and simply wrap it in wire loom that matches other wireloom in the engine bay. And that let's you wrap the ends in black tape nice and clean. Totally cost-free bit of engine bay clean-up.
You can see the matching wiring now. It just has more balance.
Old Oct 8, 2013 | 12:04 AM
insidiousaudio's Avatar
insidiousaudio
i really don't see how you get any real gains from the intakes.. you might see a few HP from a better filter over stock but other than that i doubt you get any realy power increase to spend 500 bucks on.. Id be willing to bet just adding k7n filters over stock gies nearly identical performance..
Old Oct 8, 2013 | 08:01 AM
The original post clearly laid down the ground rules... not a thread about intakes. It's a thread about fitment for the R2C intake.
God damn noobs.
Old Oct 8, 2013 | 08:39 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
The original post clearly laid down the ground rules... not a thread about intakes. It's a thread about fitment for the R2C intake. God damn noobs.
I blame rap music and vaccinations.
Old Oct 9, 2013 | 08:32 AM
  #29
Chris11LE's Avatar
Chris11LE
Jenny McCarthy, is that you?
Old Nov 6, 2013 | 04:28 PM
  #30
Bota36's Avatar
Bota36
Hey Bro, pictures of your engine inspired me to do some clean up. Not close to how clean yours is but I'm making progress.
