Finally I found headers for the Sedan
Old Feb 16, 2013 | 07:37 PM
Mohammed A.'s Avatar
Mohammed A.
Hey folks,,
So I finally found A set of headers for the sedan models.
There is two companies that make it, Megan Racing & TopSpeed Pro-1
So what is your advice on which one is better and has more HP & TQ and, if there is another company please tell.
Thanks,,
Old Feb 17, 2013 | 08:48 PM
Mohammed A.
79 views and no respond !!!!
C'mon guys I don't think I asked a difficult question
Old Feb 17, 2013 | 09:00 PM
Kevalteam's Avatar
Kevalteam
If you found it.... I think you will know better than that 79 members wo saw but did not reply to this post. Or at least put up a link? And IMO headers are too much $$$ and more money to install it to gain little...
Old Feb 17, 2013 | 09:08 PM
I viewed it twice. I still don't know the answer to your question. Would you like me to make something up and respond just to make you feel better? I'll be glad to. Which would you prefer that I suggest and what amount if HP do you want me to tell you it will give?
I wouldn't buy either.
Old Feb 17, 2013 | 09:43 PM
Mohammed A.
Well, actually I'm a little bit afraid that it'll not fit the sedan.
Before A while I was this close to buy the Stillen headers bit it was for coupes only so I emailed them and they said it'll not fits due to different design !!!
Apparently will hit the steering column unless you modified it.
And know IDK if these fits or not emailed them but no response so far
I also called and they didn't pick up
Old Feb 18, 2013 | 04:18 PM
G37Sam's Avatar
G37Sam
Word of advice, don't waste your time/money on headers.
Old Feb 18, 2013 | 04:26 PM
JohnsVert's Avatar
JohnsVert
This
Old Feb 20, 2013 | 01:45 PM
Alaa Wehbeh's Avatar
Alaa Wehbeh
why not ?? was there a previous post that stated problem having headers on the sedan ?
Old Feb 20, 2013 | 02:33 PM
ECain18's Avatar
ECain18
Use the search funtion and you will find many threads the pretty much say don't bother. They are both a waste of time and money. Also, the quality of the brands you mention are questionable. Headers experience extreme heat, so I would say do not waste your time or money on OK/Average products with OK/Average welds. They only add a couple HP at the most when combined with other bolt ons. Also, it is a very expensive mod for the amount of HP you add.
Headers: $550
Install from Nissan/Infiniti Dealer: $800
Install from Indep. Shop: $400-500
If Your happy paying $1,000 - $1,300 for headers for +3-5 hp, then go for it. I will tell you I did it and was not happy with the result. I even did F.I. Longtube headers, which dyno results proved superior to shorty headers. They power was nice from them(because of the longtube design over shorty) but the amount of rasp that it added was terrible. Also, the headers I bought were $1300 just for the headers, and the quotes above were what it was for installation.
I did a ton of **** to my car, and I mean a ton. Headers would never be on my list to add to the G or Z ever again. I'd say don't even bother, but thats just me. It's your money so you decide. I would say that if 98/100 people said don't bother. I wouldn't...
Old Feb 20, 2013 | 03:51 PM
G37Sam's Avatar
G37Sam
^ Exactly. VQ37 OEM headers are well designed already. There are pics of them side by side with Stillen's and the difference is just aesthetic.
In the Middle East, Y61 Patrols/Land Cruisers and other V8's will tell you to go headers because their OEM headers are too restrictive and due to their larger displacements. Their gains are in the tens of hp's especially when mated to aftermarket cams. Not the case with our engines though.
Old Feb 20, 2013 | 04:11 PM
daonlyillwiz's Avatar
daonlyillwiz
THIS!
Especially not that Megan garbage.
Old Feb 20, 2013 | 04:17 PM
daonlyillwiz
If you want headers for your sedan, get them made by a fabrication shop...I have a very good buddy that works for american racing headers (same company that makes headers for the dodge viper ACR) and when you get your headers made at a shop like this, sure it will cost alot of money BUT it will last much longer, it will be designed to custom fit your car, and will most likely be made of a a higher grade of Stainless Steel.
Problem is that these companies claim that their headers are stainless steel but they forget to mention the type of filler/flanges, in most cases they use a thin wall tube for the headers, and a low grade of stainless steel that is cheaper because it contains more iron (which is what rusts) than higher grades of stainless steel and the flanges are made of MILD STEEL which will rust eventually. Another important thing to keep in mind is that the welds are not proper high quality welds because it is machine made so sometimes the bond is not quite right...higher quality fabrications are made with thicker wall tubes for the runners, stainless flanges, and a high grade of stainless steel, and its all welded together by a tig welder.
Either do it right or dont do it at all.
Old Feb 20, 2013 | 05:17 PM
ECain18's Avatar
ECain18
^^ Couldn't agree more about the importance of build quality and materials, as well as what Sam said about the vq37 already having well designed headers from the factory.
Old Feb 21, 2013 | 10:11 AM
daonlyillwiz
Yea dude, just keep factory headers they arent much of a restriction.
Old Feb 21, 2013 | 11:17 AM
Think47's Avatar
Think47
Though not a sedan. I have helped a few people install headers on 370z and G37 coupes, just to see them go on the dyno and make almost no gain. Not worth it at all.
Thedbarz
33
Feb 9, 2016 12:05 AM
Dillybar12
Oct 14, 2015 02:08 PM
Glen Roebuck
Aug 26, 2015 02:42 PM
Abramite
16
Aug 8, 2015 08:35 AM
