Help Questions about the MotorDyne intake manifold M370
Old Jul 2, 2012 | 06:38 PM
Mohammed A.'s Avatar
Mohammed A.
Hey everyone,,
I've 2 or maybe 3 questions on the M370.
First; is it entirely bolt on, meaning that should I just remove the stock manifold and place the new one, i hope is it that simple.
Second; I heard that in case of changing an intake maniflod you have to change the throttle body with it, so is it true or the M370 will fit with the stock ones.
Third and last; also i've been hearing that with changing the manifold you will have to tune the car with Uprev or Cobb or the engine will not start.
Hope someone can find these answeres for me ASAP.
Thanks,,
Old Jul 2, 2012 | 07:20 PM
ECain18's Avatar
ECain18
1 and 2 are true. Bolts right up and you basically just undo your stock throttle bodies and then connect them back up to the M370 when its installed. You can use that as an opportunity to clean your throttle boddies as well. There is a DIY on here someone for cleaning them. However, it can throw your throttle off a little if they are really dirty and all you need is the dealer to reset to back to stock settings.
#3: I'm not really sure. I have the cobb Ap so before i even tried to start my car, I reset everything so I can't help you out there buddy. I just did it without thinking because I always reset my car after I do any mod and restart my car. GL hope someone can help
Old Jun 13, 2013 | 09:45 PM
Ivoidwarranties's Avatar
Ivoidwarranties
How thick is the silver plate?
Old Jun 13, 2013 | 10:52 PM
Brainchild's Avatar
Brainchild
As ECaine18 said, it is a simple swap of manifolds. You don't have to alter anything. As for the throttle bodies, all you need to do is remove the 4 hex bolts on each throttle body and it'll move aside more than enough to complete the install. No need to remove them completely like it suggests in the directions. And yes, clean them while they're off. It's easy. Tune is not necessary but recommended.
Simran Mann
Sep 13, 2015 01:51 AM
Mattlorentzoe
Aug 21, 2015 05:09 PM
RoyalG37
Aug 19, 2015 03:36 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
