Help Invidia Gemini Flex Pipe Problems
Old Nov 21, 2011 | 01:52 PM
qpham45's Avatar
qpham45
I've had my system for almost 30k miles with zero problems. But maybe i should go ahead and check the flex pipes.
Old Dec 13, 2011 | 11:43 PM
ronn1's Avatar
ronn1
I have Gemini and for the most part, it's a nice system for the price.
The flex pipes are the weak point....you get what you pay for. Get over it...please. If I ever get a crack (so far so good) I will NOT get an Invidia replacement...STUPID thing to do. Just gonna invite another failure. I will replace it with this>>> get it welded on at a muffler shop for $25.
Stainless Steel Flex Section 2.50" x 6" - Fabrication Parts - Berk Technology
There are the same flex sections used on our turbo exhaust systems. Twice the fataiuge resistance of a non- lined flex section. These are designed for high temp, extreme duty use. These are not your run of the mill "muffler shop" flex sections. Perfect for use on turbo downpipes, header applications, & exhaust pipes.
Old Dec 15, 2011 | 04:40 PM
ronn1's Avatar
ronn1
Originally Posted by kosstick
Im thinking the following:
Bad Design - Defect - Faulty craftsmanship.
I called Invidia today on their flex pipes. They are DOUBLE BRAIDED...inside and out which is good. Cheaper flex pipes are only single braided on the outside. I thought that might have been the problem here...we can rule that one out.
Old Dec 16, 2011 | 12:37 AM
kosstick's Avatar
kosstick
I got the replacement pipe for the right side of the exhaust, They moved up the Flex pipe a little further up towards the resonator, A little disappointed that I only got the right side, Will wait to see if left one gives.
Old Dec 16, 2011 | 02:12 AM
ronn1's Avatar
ronn1
Could you check inside the tube with a flash light and see if the flex section is braided on the inside? Just want to confirm what they told me on the phone.
There are 3 types:
Worst...Single braid with flex tube inner:
Better...Double braided with flex tube between:
Best...Interlocking metal tube inner and outer braid:
Don't confuse the FLEX TUBE with the INTERLOCKING TUBE!
Here's a good post on this:
http://forums.audiworld.com/showpost...82&postcount=1
xnick101
Jul 23, 2016 11:46 PM
xnick101
Nov 12, 2015 04:58 PM
fysemi
Oct 2, 2015 04:06 PM
rgs3
Sep 14, 2015 04:22 PM
rgs3
Intake and Exhaust
Sep 9, 2015 03:10 PM
