Could Infiniti make it harder to instal test pipes?
Old Dec 4, 2010 | 09:17 PM
MyocyteX's Avatar
MyocyteX
Spray them generously with the penetrating lube of your choice (I prefer Kroil or PB Blaster) and let them sit at least overnight. A day or two is better. That should make it much easier. Use a 6 point socket to try to avoid rounding off the corners.
It's a tough job but they'll cone off, stick with it. Good luck.
Exactly... i.e. Work smart, not hard.
Old Dec 5, 2010 | 01:21 AM
Another thing that may help is to have 2 guys on the end of the ratchet to apply more force if you have a second person available to help.
As was mentioned, heating it may cause you to break it off. Which can be a PITA if you snap it off in a place you don't want it to break and make the job even harder.
Old Dec 5, 2010 | 01:47 AM
Neal376's Avatar
Neal376
Originally Posted by Steveo47
Okay so! The consensus is: spray the hell out of it with a liquid wrench. Hit the bolt a few times to let it seep in a bit. Then leave is for 12-24 hours. Then it should be a lot easier. How exactly could I heat that bolt (like with a propane tourch). A few people have said it helps
no man
-spray pb blaster...or wd40...or liquid wrench...whatever you choose. douse the bolts in the sprays. Let them "soak in" for as long as whatever the directions on the can say.
-work on the bolts when everything is stone cold...i.e. not after a drive
-use a "cheater bar" on your wrench. ( this is a cheater bar Cheater bar - Wikipedia, the free encyclopedia )
there is no bolt that wont come off with the combination above ^^^ the "cheater bar" I use is 6 foot long steel pipe that fits over my wrench handle.
the whole "heating" thing...you usually do this on axle nuts or crank pulley nuts. you heat what goes through . i.e. you heat the nut while you leave the stud/bolt cold. you cant do this on the exhaust pipes nuts because the nuts are just too small for convenience if you heat the nut and bolt together, you can snap the stud .
i dont know what you are talking about by "brace". just twist that wrench mang
Old Dec 5, 2010 | 02:05 AM
Steveo47's Avatar
Steveo47
Originally Posted by Neal376
no man
Thanks for the summary, im a noob. Ive never done anything to a car before this so its all new! Im aware of a cheater bar, my friend who was doing it with me kept refering to it as a snipe. When i try to twist the bolt with the long extension, the extension tends to bend and push on the engine block, which they just pushed the engine block to the side. So im losing alot of force. by brace i mean putting something on two solid spots in the engine bay (which im not sure where they are) so when i turn the ratchet, it stays straight and leans against the brace instead of the engine block.
Old Dec 5, 2010 | 04:18 PM
Steveo47's Avatar
Steveo47
Did anyone get thier test pipes/ HFC's installed at the dealers? if so what did they quote you?
Old Dec 5, 2010 | 04:37 PM
EnviedG35's Avatar
EnviedG35
Pb blaster, a bunch of 1/2" extensions and some universal joints, and a 24" breaker bar, along with my big guns = an easy task for me lol
Old Dec 6, 2010 | 01:07 AM
Many dealers won't touch this job. Mine charged $250.
Old Dec 6, 2010 | 01:27 AM
da mayor's Avatar
da mayor
its a legality part that is non compliant that is why they wont touch it
Old Jan 8, 2011 | 08:47 PM
bsowhat1's Avatar
bsowhat1
This install is a PITA for sure. The upper studs on the OEM cats will likely break especially if you use an impact wrench to remove them. There is just not a lot of space to turn wrenches. It is doable. You just need the right tools.
superjoey
31
Mar 22, 2023 11:56 PM
Dsskyline
ECU Tuning / Dyno Data
91
Oct 9, 2016 01:24 PM
reigle9
Aug 6, 2015 02:45 PM
