MAF screw snapped off
Old Aug 11, 2010 | 08:52 PM
Frankyg37s's Avatar
Frankyg37s
i was instaling the r2c intake on my car
I installed everything but when i tightened the last MAF screw at 90% tight it SNAPPED OFF!! The maf is on but i dont know if im able to remove it becose theres a piece of screw in the maf screw hole/intake tube, i drove it around for 20 mins and everything seems fine.
BUT now the a piece of the maf screw is stuck how the hell would i get it out??
man i f-up
Old Aug 11, 2010 | 09:01 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
just leave it in there, and re-tap it, and put a new screw in. This time don't use a drill or tighten them that much, because they snap! Just like the Jet-Blue guy did!!!! Snapped! LOL
Old Aug 11, 2010 | 09:10 PM
Frankyg37s's Avatar
Frankyg37s
yea i could leave it there but what about when i want to take it off i will be fuc**ed and i was tighteninig it by hand when it snapped!!!what do you mean re -tap it and put a new screw in???
Old Aug 11, 2010 | 09:12 PM
Weiboy718's Avatar
Weiboy718
there's some drill bit you can buy that'll extract the broken drill bit.
Old Aug 11, 2010 | 09:21 PM
Frankyg37s's Avatar
Frankyg37s
even if the piece is flat flush .
i dont see that happening like that
Old Aug 11, 2010 | 09:29 PM
You must have used way too much torque tightening it down. It doesn't need to be tightened much.
That's a very small M4 screw. You can get a very small drill bit and drill a hole in the broken screw and use a spiral screw extractor and back it out. Good luck.
Old Aug 11, 2010 | 09:42 PM
GraphiteG37S's Avatar
GraphiteG37S
What blackbetty said... I think it's called an easy out. Screws into screws and bolts who heads broke off to help extract them
Frankyg37s's Avatar
Frankyg37s
luck i will need and i swear my dude i did not use to much force the screw was corroded becose of winter ... your idea sounds like a good option tho
any others ideas thanks
Old Aug 11, 2010 | 09:51 PM
Given your mechanical aptitude, I'm going to suggest you remove that part of the intake tubing and take it in to an automotive machine shop and ask them to do it. They have the tools and skills to do it easily. Probably won't cost much more than buying the tools to do it yourself. And they're probably better equipped.
Old Aug 11, 2010 | 10:04 PM
Frankyg37s's Avatar
Frankyg37s
yea probly what ill do but ill just drive the car there and have them look at it first thats about all i can do thanks all
Old Aug 15, 2010 | 12:10 AM
Frankyg37s's Avatar
Frankyg37s
up date took the bolt out with drill and re thread it LIKE NEW thanks for help
Old Aug 10, 2024 | 11:39 PM
z34Angel's Avatar
z34Angel
can you help me pls
do you know where I would take my care to have it extracted? this happened to me right now I was finishing up cleaning my MAFS and I was screwing it back on and i felt the screw a bit loose so i tightened it and the bolt snapped off now the other half is stuck inside the MAFS hole. pls respond to me asap as im in a panic bc i don’t want anything bad to happen to my car.
37
Oct 17, 2020 11:12 AM
vamarris
Dec 9, 2018 11:10 AM
delfinparis
Nov 16, 2015 02:26 PM
Jonesmeister11
Sep 27, 2015 08:28 PM
ZachThomas
Sep 3, 2015 01:40 PM
