Review Saclam Exhaust on a 370Z.. WOW!
Definitely a weird looking set up, but I honestly don't hear the huge difference in sound. Sure, in the parked position it sounds a little exotic but I have a feeling that's more due to the resonance of the "garage" that they are parked in. In the video below the car sounds like any other loud exhaust kit.. maybe a touch different but that's it.
<object width="660" height="405"><param name="movie" value="http://www.youtube.com/v/lAi2krggqgk&hl=en_US&fs=1&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lAi2krggqgk&hl=en_US&fs=1&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="405"></embed></object>
Frequency= 330m/s[ speed of sound in air] divided by 2 times the LENGTH of the tube [ standing pipe, blinded pipe]
It is easy to kill the frequency you don't like by adjusting the length of the resonator pipe. Don't cheat yourself, anything below 70hz is insignificant because we will not hear it very well. So we should concentrate on the audible frequencies which start above 100hz. There aren't many choices because we are limited by the length of the resonating pipe from both ends- it can't be to long because it will kill the lowest frequencies we do not hear. It can't be to short cause the air has to get a chance to vibrate.
Anyway for those of you who wondered why these blinded pipes, here you are.
By using the Helmholtz resonators[ the skinny pipes] they've managed to give this exhaust a very defined note sort of a center pitch which is very apparent in high rpm range. Listen to it ,it almost plays a clear tone.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
Dillybar12
Sep 14, 2015 12:54 PM
