High Flow Cats - How noisy?
About to pull the trigger on phase 1 of upgrades (finally). HFC's seem an essential airflow upgrade, although I was initially hesitant due to "off road use only" warning. I guess I'll just keep the old ones and bolt em on before I get inspected. Tints are already illegal so might as well go for it huh?
ANYWHO, will the stillen hfc's be obnoxiously noisy? I assume they will not be as loud as test pipes, right? I've listened to alot of video, but it's still hard to tell what mod their noise is coming from.
Well I know SOLISIMO wrapped his Test Pipes (Which are raspier then HFC's) with header wrap. It eliminated the rasp on his set up. But I don't think anyone has tried it with HFC's. Not sure if it would have the same effect or not
Interesting - that's the main reason I'm leaning toward a stillen exhaust is b/c they seem to yield decent gains while still sounding reasonable. We have a neighbor who has an old accord with a bolted on exhaust and what must be test pipes, and the whole neighborhood knows when he's coming/going. I want her to growl when I step on it, but I don't want to be
that
guy!
Could anyone link me a stillen hfc/stillen exhaust combo sound clip? That would make my decision easier...
...altho I just might say F it and do it anyway
that
guy!Could anyone link me a stillen hfc/stillen exhaust combo sound clip? That would make my decision easier...
HFC will not increase your noise obnoxiously but it will be slightly louder. AS SOLISMO said, what you'll notice is an increase in raspiness. I have HFC and Invidia Cat back which doesn't have any resonators in the mid pipe. Is it not loud at all. It is very similar to stock in noise level; it has a metallic rasp and the hiss common to HFC when you let off the accelerator, but it's not loud at all. No I don't have any video.
Here is how mine sounds with Berk HFC and magnaflow exhaust. I have other vids if you want.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hJ0K290U0VE&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hJ0K290U0VE&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
hfc's will definitely make your exhaust louder:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/lVSTz80aV9g&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lVSTz80aV9g&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Aliiin and Dipstix,
Thanks so much, both were very helpful, and I'm going to do it!
The dyno's I have seen on HFC's portray them as one of biggest single gainers out there in terms of bolt on mods. The noise increase is there, especially when u really get on it, but neither was obnoxious in my opinion. The aggressive sound is good IMO - should be more pronounced with CAI and exhaust.
So I should keep my stock cat's so I can pass emission testing right?
The dyno's I have seen on HFC's portray them as one of biggest single gainers out there in terms of bolt on mods. The noise increase is there, especially when u really get on it, but neither was obnoxious in my opinion. The aggressive sound is good IMO - should be more pronounced with CAI and exhaust.So I should keep my stock cat's so I can pass emission testing right?
Aliiin and Dipstix,
Check out this video taken from a bumper mounted camera. It's a 370Z with BERK HFC's. The 370Z has the same motor, same HFC's, and same stock exhaust as the G37. So this is pretty much what your car will sound like with the BERK HFC's on there and nothing else.
http://berktechnology.wordpress.com/ - it's about 2/3 the way down. Sounds even better in the cabin!
Some have done it on test pipes but none on HFC's. HFC's quiet the exhaust down a great deal compared to test pipes. Plus, heat wrapping an exhaust part will greatly shorten the lifespan of any exhaust part. Most manufacturs will void your warranty if the parts have been wrapped.
