Test Pipes & CEL (Check Engine Light)
Old Dec 17, 2008 | 06:05 PM
grippy's Avatar
grippy
Ill start off by saying I already tried finding CEL info on the forum but didnt seem to pull it up. Im looking to put test pipes on but I dont want that check engine light turning on. Does anyone here have a definate working solution (preferrably bolt on). I do not want to disable the light entirely and yes I am aware they make aftermarket cats. Let me know what you guys have done so far. Thank you.
Old Dec 17, 2008 | 06:07 PM
shumby's Avatar
shumby
there are non-foulers but they only work some of the time. I know Fastintentios is working on a fix that will be 100% but it is not out yet. Should be soon and that is all I can say.
Old Dec 17, 2008 | 06:08 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
^ +1 to what shumbalaya said...
Old Dec 17, 2008 | 06:23 PM
grippy's Avatar
grippy
Well good enough for me. I want to do it right the first time so I will just wait until he is done with his diabolical invention Also too since Im not usually on the forums alot if you could reply to this post when something else comes out that would be great and it would also help out the others that search for this same problem I am having. Thank you guys.
Old Dec 17, 2008 | 06:31 PM
SOLISIMO's Avatar
SOLISIMO
I just bought the new Ichiba test pipes from Andy @ HPauto, they are supposed to fix this problem in there by moving the o2 censors father away, we'll see
Old Dec 17, 2008 | 07:30 PM
terrycs's Avatar
terrycs
No SES light from my set up:
The J-bends are hollow.
Old Dec 17, 2008 | 07:31 PM
SOLISIMO's Avatar
SOLISIMO
which one are those?
Old Dec 17, 2008 | 07:33 PM
shumby's Avatar
shumby
the spacer are hit and miss works on some not on others. there is no 100% fix out there yet.
Old Dec 17, 2008 | 07:37 PM
terrycs's Avatar
terrycs
Mine were made by GTM.
Old Dec 17, 2008 | 09:57 PM
tristan1334's Avatar
tristan1334
I had a pair similar to that from AAM and still gave me A SES light. I replaced it with a HFC and still gave me a SES light. No solution yet and hopefully someone gets a fix for it before my emission testing.
Old Dec 18, 2008 | 08:32 AM
BigDan727's Avatar
BigDan727
Try clearing the code after the HFC install. This should prevent the light from coming back on with the hfc's
Old Dec 18, 2008 | 09:12 AM
G37Sam's Avatar
G37Sam
get your ECU flashed
Old Dec 18, 2008 | 10:19 PM
tristan1334
Thanks Dan, I did unplugged the battery for 24hrs. SES was gone but came back 2 weeks after. I'll get the dealer to read the codes and see from there.
Old Dec 18, 2008 | 10:24 PM
tristan1334
Still debating about flashing. AAM re-flashed my freinds 08 Nismo and gain 11whp & 13wtq for $516.
Old Mar 30, 2020 | 02:47 PM
Mirwais Sarbaz's Avatar
Mirwais Sarbaz
Hey! Hate to bring up an old thread but did anyone have a sure fire solve for this? 2013 with previous owners work that’s left the cel on. Thank you in advance!
