JWT fitment
Old Dec 1, 2008 | 01:04 PM
wrathletik1's Avatar
wrathletik1
Originally Posted by ucla bruin
I had to take off that black stock mounting piece to make it work. I took that off, mounted it with the JWT's bracket first then screwed it back onto the frame. The angle still wasn't perfect. The bracket is also hitting the bottle on the passenger side.
That's what I tried to do, but the hex broke off the screw!! I hope I can remove it. The dealership is gonna charge an outrageous price for a replacement screw, I just know it...
Old Dec 1, 2008 | 01:12 PM
erasat's Avatar
erasat
I have broken the 2 screws myself adjusting and removing, but locally we have a store called "Casa de los tornillos" (House of screws) that can get you whatever you need, I got 4 of those for $2. That way I replaced the 2 I broke and kept 2 just in case.
Old Dec 1, 2008 | 01:28 PM
ucla bruin's Avatar
ucla bruin
Try local hardware store like Home Depot? How did you break off the hex from the screw? Haha.
__________________
Old Dec 1, 2008 | 07:01 PM
SteveG37's Avatar
SteveG37
Originally Posted by wrathletik1
I bet that the "fixed" bracket that came with Steve's intake allow him to have the mounting setup he has, while those of us with the original brackets are stuck with sh!itty fitment.
You know it's funny u say this because I was thinking the same thing today, while my bracket was still not correct while following the out of box instructions maybe it was changed enough that I was able to pretty easily get mine to both line up perfectly with the method that I used. I starting thinking that if UCLA is having such trouble, maybe my brackets are different. Maybe Andy from HP can shed some light on whether or not JWT actually did alter the brackets?
Old Dec 11, 2008 | 11:43 AM
Ahujadaddy's Avatar
Ahujadaddy
Hey guys, i knew what i was in for with the install, but just wondering if there was any update on this from the OP? I'm havin the same issues of course, and am trying some suggestion that you guys have made. I hafta go to Home Depot today to get some more bolts because i am actually missing one that should have came with the intakes. I'll just pick up some extra as well while im there.
I really dont see how the passenger side braket will attach to the filter. Gonna try removing the black mounting peice from the frame.
It seems so odd for this filter to fit, because i dont see how it can get down past and clear the power steering fluid bottle. >_< Any advice guys?
Attached Thumbnails JWT fitment-passsidefar.jpg   JWT fitment-passsideclose.jpg
Old Dec 11, 2008 | 11:22 PM
Ahujadaddy's Avatar
Ahujadaddy
is this what happens when ur one of the last on the GB list? lol.. can't get a response around these parts cuz the topic has been beaten to death?
Well... i'm with you guys! This g@t damn ****** fvckin peice of **** was a b!tch!!!! But it def does sound niiiiiiiiiiice now =)
So i never got the screw in.... gonna hafta do something about it later. and also the rubbing against the power steering fluid bottle cant be good. =\
Old Dec 11, 2008 | 11:45 PM
NeverBoneStock's Avatar
NeverBoneStock
The fitment of the intakes is pretty bad .. Thats why i sold mine ...
Old Dec 12, 2008 | 07:40 PM
ucla bruin's Avatar
ucla bruin
Are you still having problems? I can try to help
__________________
Old Dec 12, 2008 | 08:18 PM
wrathletik1
Ahuja, I think you may have got the wrong side bracket on the passenger side.
Old Dec 13, 2008 | 02:23 AM
ucla bruin's Avatar
ucla bruin
The 2 brackets are of different length. I used the shorter one on passenger side and longer one on the driver side I think.
__________________
Old Dec 21, 2008 | 08:44 PM
ghostfaced37's Avatar
ghostfaced37
glad i read this thread... i guess im going to hold on buying JWT intake
Old Dec 21, 2008 | 08:59 PM
ucla bruin's Avatar
ucla bruin
In hindsight, if I were to do an install for someone right now. I'm pretty sure it can be done in under an hour, without heat wrap. As long as you have an idea of what you're getting yourself into, and with the help of the forum, it shouldn't be that bad.
__________________
Old Dec 25, 2008 | 11:05 AM
Ahujadaddy's Avatar
Ahujadaddy
yea i used the short one on the passenger side. idk what it is but i never cd get the screw to go in the hole as shown in the pic.
im considering using a heavy duty zip tie.... >_< lmao... like the ones i get with Betty's grounding kit.
Old Dec 25, 2008 | 04:52 PM
  #29
ucla bruin's Avatar
ucla bruin
It looks like you're very close in the first pic. Try taking off the black metal bracket from the frame, attaching it to the JWT bracket first. Then twist and turn the whole thing little by little to get it to go back onto the frame.
That's what I did, took that off, attached it to the JWT bracket first.
__________________
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
Italia311
Jun 28, 2016 11:25 PM
VIVID
Sep 29, 2015 10:58 AM
pal51961
Sep 27, 2015 08:38 PM
kinchi
Sep 25, 2015 12:04 AM
