Fujita Intake Review
Old Jul 31, 2008 | 06:37 AM
  #31
ironchef2008's Avatar
ironchef2008
You show two sets of numbers in each column seperated by a / Just want to know what the difference is between the number before and after the /.
Sorry for not explaining that. The first number is for the passenger side intake and the second is for the driver's side.
Old Aug 1, 2008 | 08:59 PM
  #32
ironchef2008
Bump for updated chart on page 2!
Old Sep 3, 2008 | 09:08 PM
  #33
G37Sam's Avatar
G37Sam
ironchef thanks alot for the info, fujita intakes it is!
and yeah its noticable how the shield manages to trap all the hot air in there.. and 6 hp gains without reflash sounds interesting
cheers to your efforts
Old Sep 4, 2008 | 03:44 AM
  #34
NeverBoneStock's Avatar
NeverBoneStock
Originally Posted by ironchef2008
Three key factors noted thus far:
  • Coolant running through stock throttle body makes it a constant source of heat no matter which intake is used. Even cold air once it approaches this area will be warmed regardless of the metal versus plastic debate. To truly achieve the coldest air possible, the lines need to be removed and a shut off valve installed ala Motordyne.
  • The aluminum tube of the Fujita was consistently cooler at the air sensor location or intake tract 1. Further, the metal cooled FAR faster after the heating period. I've seen this fact in the lab as well where I work. Plastic resists temperature better than metal at first but once hot or cold, it takes over three times as long to return to ambient. After both tests, I couldn't leave my hand on either intake for long as they were BOTH hot. But after ten minutes the Fujita was 22 degrees cooler while the stock plastic had cooled only 6 degrees and was still untouchable.
  • The entire engine compartment is pretty warm. I find it hard to believe that there's enough of a difference in the density of oxygen in the temperature differentials between the stock and Fujita intake to claim that either one would more so suffer from heat soak or that there's a power loss. While the Fujita has proven to be an improvement in temperature and power thus far, I believe the big part of the test is yet to come: Will properly insulating the intake protect it from the engine compartment enough to drop the temperature closer to ambient.
Tomorrow is supposed to rain but I'll get on that one next!
The mod from motordyne that does not allow coolant to pass to throttle is called iso thermal I believe. I had it on my z and made a difference in temp .. Ill call Tony to see if it works on g37 ...
Old Sep 11, 2008 | 08:09 PM
  #35
Dynamics's Avatar
Dynamics
Intake concerns - testing
There may be another problem associated with the Fujita equipped cars. Lab flow testing is attached.
While the JWT and Stillen/KN filter restriction levels rise quickly as loading occurs, this is alarming.
Dynamics
Old Sep 11, 2008 | 08:15 PM
  #36
TerribleONE453's Avatar
TerribleONE453
bump for the iso thermal part
Old Sep 12, 2008 | 07:00 AM
  #37
ironchef2008
What is R2C? Are you a vendor?
Old Sep 12, 2008 | 09:47 AM
  #38
Dynamics's Avatar
Dynamics
R2C Performance Engineering
ironchef2008
R2C Performance is a design, engineering and manufacturing company that produces state-of-the-art intake systems and filters utilizing a patented and proprietary process with testing labs on the premises. Evaluation of competitor performance products began in 2007.
The company history is that of a designer of sophisticated, severe duty military filtration for the last several decades.
Contact from prominent motorsport teams with a desire to resolve their system/filter concerns led to the development of the new street/competition product line including Nissan and Infiniti products.
Filter performance is unmatched in every category of measurement. It completely eliminates the reliance on poor performing oiled cotton gauze, foam and other restrictive synthetics.
Thanks,
Dynamics
Old Sep 12, 2008 | 11:37 AM
  #39
ironchef2008
ironchef2008
Thanks,
Dynamics
It's great to see you post here on the forum but as a vendor, posting in a Fujita topic is frowned upon. If you have an alternative to the Fujita and others please post it up as a new topic. Other than that, welcome aboard!
Old Sep 12, 2008 | 12:23 PM
  #40
Dynamics's Avatar
Dynamics
Fujita Review
My mistake.
I thought that the lab test analysis of the Fujita product was appropriate with the understanding that this was a performance review.
Regards,
Dynamics
Old Sep 12, 2008 | 12:28 PM
  #41
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
he is not a vendor... and the second he acts like a vendor all his posts will be deleted. He is free to comment on what he wants... as long as he is not selling things. Keep that in mind dynamics...
Old Sep 12, 2008 | 12:36 PM
  #42
MaxToTheG37
was that a spacer you were talking about? if so Tony said a while back that the 37 motor cant have that added to it... which sucks...
Old Sep 12, 2008 | 05:15 PM
  #43
ironchef2008
I'm confused. It states clearly here that R2C Performance has developed products for Nissan and Infiniti. Further, the graph shows testing on the Fujita and a yet to be described R2C filter. This to me is the definition of a vendor. R2C is making a claim of superiority over Fujita in a Fujita thread.
You don't need the spacer to bypass the coolant. You only need the little valve deal and I'm sure Tony would sell that for us G37 guys.
Old Sep 13, 2008 | 03:29 AM
  #44
MaxToTheG37
he can make all the claims he wants... as long as he doesnt sale anything....
Old Sep 13, 2008 | 01:34 PM
  #45
bboysteele's Avatar
bboysteele
^^And as long as it is not in a "Vendors Thread" either. The threads in the intake/exhaust section are ok.
