Dyno Vids of Injen Intake!
Old Apr 14, 2008 | 07:01 PM
  #61
NemesisG37's Avatar
NemesisG37
im 100% sure we need two.
Old Apr 14, 2008 | 10:24 PM
  #62
f0ki187's Avatar
f0ki187
lol. You guys know exactly what I mean !
Old Apr 14, 2008 | 10:33 PM
  #63
TerribleONE453's Avatar
TerribleONE453
hahah not sure yet...
Old Apr 15, 2008 | 12:44 PM
  #64
NJKSC27's Avatar
NJKSC27
i must add that unless the Injen is guaranteeing 12+ hp gains it will be a waste. I had an Injen CAI on my acura tsx and it had nice gains of around 12-18hp for around $350 not to mention the great growl it gave off. I think the G is quite fine with the stock setup but my modding itch is starting to grow. i truly think , like most of you are saying, to unleash substantial gains its gonna require a complete setup...intake to exhaust. right now im just looking for some nice aesthetic mods.
Old Apr 15, 2008 | 02:23 PM
  #65
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Id be happy if it gains +8whp
hoping for +12 whp though...
Unrealistically hoping for +15-16whp... lol
Old Apr 15, 2008 | 03:08 PM
  #66
DetroitG37Joe's Avatar
DetroitG37Joe
will the pedal pump ECU reset be sufficient post intake install?
or do you guys plan on doing the complete data dump with the battery disconnect??
Old Apr 15, 2008 | 03:11 PM
  #67
NJKSC27's Avatar
NJKSC27
hmmm, i dont know, 8hp gain from the Injen might not sway me into just an intake swap.
Old Apr 15, 2008 | 03:12 PM
  #68
NJKSC27's Avatar
NJKSC27
im pretty sure a data dump and intake swap will trigger the check engine light and it will have to be reset by the dealer
Old Apr 15, 2008 | 03:17 PM
  #69
MaxToTheG37
Pedal pump... that made me laugh... never heard it called that...lol.... pump away...
Never heard on resetting the ECU either way throwing a code... what code are you sayin it will throw?
Old Apr 15, 2008 | 06:00 PM
  #70
TerribleONE453
yea same question as max... if anything it would cause it to reset the code...?
Old Apr 15, 2008 | 11:15 PM
  #71
KahnQuistador's Avatar
KahnQuistador
Gents, if you're working on the car, pull the neg battery cable first.
That will reset the ECU. No need to visit the dealer.
If you screwed up and the CEL stays on, you have a problem. Then visit the dealer. Things like the LTP might take a few miles to reset.
Don't forget to do the window reset.
Terrible, any luck with that Cobra NO2 set up? JK.
Old Apr 15, 2008 | 11:17 PM
  #72
EZDozzit's Avatar
EZDozzit
No Soliciting
Window reset?
Old Apr 15, 2008 | 11:46 PM
  #73
TerribleONE453
you gotta close the window and then hold up on the switch for 3 full seconds or your windows will act EXTREMELY weird... and i was not the one who said i would do that.. got the wrong guy
Old Apr 16, 2008 | 09:27 AM
  #74
NJKSC27's Avatar
NJKSC27
yea when i picked my car it had multiple problems, probably cause it wasn't PDI'd right to begin with. But i had all kinds of issues with check engine lights, flat tire sensors, auto window controls, SRS sensors, etc..you name it, i had it. And i had some lengthy conversations with an A Tech and the service manager and there going on and on about how touchy and intricate the 37's computer system is and the process for the diagnostics. Anyway, any number of sensors can be triggered from any number of problems. And a intake swap along with a battery disconnect can trigger multiple sensors. Apparently this is "new" to the infiniti's and has caused some problems already. And unlike previous models, NONE of the sensors or alarms can be turned off besides the obvious low gas alarm.
Old Apr 16, 2008 | 09:47 AM
  #75
MaxToTheG37
On the 2k2/2k3 maximas, disconnecting the battery would NOT reset the ECU. You had to do the ECU Reset to get things reset... Its not hard plus you dont loose radio presets and memory stuff.
I dont think anyone has had any problems with sensors so far on an intake install...
