Need help putting Sevas rims on my G37s
Old Jul 20, 2011 | 12:38 AM
M3style's Avatar
M3style
Okay so I picked up these Sevas rims S-22 the front are 8.5 width with offset of 40, does anyone know what size hub centric spacers I will need to make them work on my G37s n if I would need ones for the back rims which are 10 width, the rims are 20"?
Old Jul 20, 2011 | 12:47 AM
lsondubz's Avatar
lsondubz
for reference; s22 was only made with 10" rear
Old Jul 20, 2011 | 12:50 AM
M3style's Avatar
M3style
Thank you, I just had them balanced n the guy said they were 11 but thanks any idea about the size spacers?
Old Jul 20, 2011 | 12:53 AM
breftayka's Avatar
breftayka
the center bore is 66.1mm so you would need your spacer to be 66.1mm to be hubcentric. 25 mm in front will be a nice somewhat aggressive stance. If the rears are a +40 offset also then a 15 or 20mm would work to go with the front.
Good luck with Sevas man. I've heard they are pretty weak.
Should ask if you're lowered?
Old Jul 20, 2011 | 12:56 AM
M3style's Avatar
M3style
Thank you for the size n yea I didn't know that about the Sevas, someone told me they were good n I got a great deal on a set of used ones with new tires. Just wondering online when I look up the spacers they go by mm n the spacers I has were 10mm n they weren't big enough any idea which size I would need or type of spacers would work best?
Old Jul 20, 2011 | 01:00 AM
M3style's Avatar
M3style
Thank you so much for the help n no the car is stalk height nothing lowered or changed.
Old Jul 20, 2011 | 01:04 AM
breftayka's Avatar
breftayka
If you plan to keep it that way, you may want to go a little conservative on the spacers. Maybe take off 5mm on both.
Old Jul 20, 2011 | 01:38 AM
M3style's Avatar
M3style
Thank you for all the help.
JoshB
Oct 15, 2015 03:08 PM
mitchlt
Aug 20, 2015 03:44 PM
Zach Stewart
Aug 18, 2015 05:01 PM
zzww1251
Aug 8, 2015 06:19 PM
