Oil pan gasket leak
Old Oct 28, 2025 | 01:52 PM
crazyone's Avatar
crazyone
Oil pan gasket leak
Hi, 2014 Q60 55k miles. oil changed yearly,
A few drips on the driveway led me to searching for an oil leak.
When placing paper around the oil pan i can see oil seaping through, right on the gasket line in a particular area. (not from above, not from drain plug or filter)
Luckily one of my photos captured what looks like a damaged section shown in the white-ish gasket.
I''ve purchased a new gasket and will attempt the removal and install.
It looks pretty straight forward but I'm wondering if there are any additional tips you can share and any idea why the existing would fail me at low-ish mileage. Looks like a chunk is missing.
Old May 31, 2026 | 05:31 PM
Tractionless's Avatar
Tractionless
I replaced the gasket to no avail. Tore it back down and noticed somehow many of the pan bolt holes were dimpled up toward the transmission mounting flange, I used a torque wrench during install. No clue how this could even happen between 2 flat surfaces but a new pan and another new gasket fixed the leak. Remember the OE bolts are torque to yield and only to be used once. I bought non-torque to yield bolts and employed without issue.
VQAusti
Mar 8, 2024 09:48 AM
Jcballer1333
Nov 27, 2023 10:54 AM
pahanorlando
May 26, 2023 08:51 PM
ZL1Gimpelson
Feb 28, 2016 03:30 PM
Stanced370Z
Dec 10, 2008 11:39 AM
