Help Loud whine noise, please help
Old Jan 29, 2024 | 06:07 PM
Jayjayy's Avatar
Jayjayy
Can anyone recognize this noise? I just did a tune up and fixed a mis fire, cleared the codes and this noise started happening instantly. Car drives fine and no codes yet
File Type: mov
Old Mar 2, 2024 | 02:29 PM
Twitch Williams's Avatar
Twitch Williams
Did you figure out what was causing the noise? Mine does something similar after replacing valve cover gaskets and spark plug tube seals (also t-body and upper plenum gaskets) except you only hear mine at open throttle, not at idle.
Old Mar 2, 2024 | 03:39 PM
SkysG37's Avatar
SkysG37
Sounds like a vacuum leak, maybe
check all yer hoses first
good luck
frankie951
Aug 12, 2022 09:15 PM
Avery Madrigal
Jan 27, 2022 10:02 AM
Fico
Jun 27, 2013 03:51 PM
kai
Sep 5, 2011 09:47 PM
ChrisBLKG
Aug 19, 2010 01:10 AM
