Airbag light is flashing
Old Oct 14, 2023 | 12:44 PM
Snowfun71's Avatar
Snowfun71
My airbag light suddenly started flashing. One day the car was slow to start, turns out the battery was going bad. After jump starting with a jump box I noticed the airbag light was flashing. I installed a new battery checked the charging system all good, I also checked the airbag fuse next to the parking brake. Fuse was good. Anyone know what else I can check. Vehicle has not been wrecked, I’ve had it for two years…
Old Oct 14, 2023 | 05:08 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Here's a reset you could try:
Old Oct 14, 2023 | 08:02 PM
Snowfun71's Avatar
Snowfun71
Thanks 13_SklineSedan, I tried it 3 times as in the video and even 4 times as per other comments. Now it does one long and seven short flashes. Any ideas?
Old Oct 14, 2023 | 08:35 PM
ILM-NC G37S's Avatar
ILM-NC G37S
It appears that, somehow, you entered the self-diagnostic function. Unfortunately, "7 flashes" indicates a major malfunction within the control unit:
The ACU has capacitors that store a small charge to allow for airbag deployment in the event of battery damage.
My guess? With your low battery issue the jumper pack may have caused a power spike that shorted the SRS control unit ("ACU").
Wish there was better news but it appears that the ACU has to be replaced.
Old Dec 14, 2025 | 03:14 PM
STownSaint's Avatar
STownSaint
This worked like a charm for me!
Started my car after it was sitting for weeks in increasingly low temperatures (down into the 20s). Airbag light was blinking
i did the car on/off procedure 3 times as noted above, making sure each time to turn the car off right when the airbag light turned off.
After three tries, I started the car up, but the air bag light was still blinking. But more slowly.
Did the on/off procedure once more, and that did the trick. Airbag light is off for good now. And my car is now going on a battery tender for the rest of the winter.
Thanks for the useful comments here
Tom Solimeo
General Tech Questions
Mar 6, 2020 03:04 AM
Etiennear
Aug 19, 2019 11:57 AM
bean_vq37vhr
Sep 15, 2016 06:28 PM
shawnberry45
Sep 7, 2012 12:20 PM
itsaGthing
TSB - Technical Bulletins
Nov 25, 2008 12:16 PM
