Radiator questions
Maybe take a wire brush or some scotchbrite to the aluminum heater core pipes to clean/ roughen up the surface prior to installation.
P.S. getting the heater cores off the engine side will be even more challenging that the side by the firewall.
The line going down behind motor on the passenger side was wet when I tried remove it yesterday. Didn't think much of it considering it was raining but that's probably it. Once I get the scrap blazer out of my garage I'll start on that. Hopefully this week. Brass does seem like a good choice over plastic, might have a fitting at work I can use. I've seen some people use those cable clamp plier things to get at the stuff up against the firewall. Might get some of those too.
jnelso61
Nov 15, 2017 10:51 AM
JSolo
May 24, 2013 09:53 AM
