Is My Power Steering Pump Failing?
Old Jun 16, 2021 | 01:06 PM
ZzBloopzZ's Avatar
ZzBloopzZ
Question Is My Power Steering Pump Failing?
All,
I have a 2013 G37X Sedan at 66k miles. I went on a 10 day road trip where I rented a 2021 Audi Q5 and drove 1500 miles. When I came back to the airport where my G37X was sitting for 10 days, I noticed how hard the steering wheel was to turn. I felt like I had to use quite a bit of muscle. I can't tell if I just got used to the Q5 with the nice electric steering or if there is an issue with the PS in the Infiniti. However, I will say it "does" feel harder to steer then before.
Stupid question I'm sure but how can I tell/test if there is an issue with the Power Steering? For the record, I changed out the PS fluid roughly 1.5 years ago and the fluid is still at the full line. When I start the car and look at the PS fluid reservoir I do notice the fluid is moving around quite quickly even if I hold the reservoir still with my hand so I assume the pump is moving? I don't hear any noises from the pump that I am aware of. Perhaps I should try turning all the way to the end from left to right to see if there is any sound?
Thanks!
Old Jun 17, 2021 | 01:33 AM
Said Amir's Avatar
Said Amir
You can turn it left and right, and see if there is any whining noise. But, I personally think that after driving the Q5 it makes you think the steering wheel is a lot heavier than it was previously. This happens to me after driving my sister Macan for a day. You can also try getting a hold of a code scanner and see if you have a P0550 code. This code will not trigger the check engine light. Its a power steering pressure sensor which is located in the engine bay on the front corner of the passenger side.
Glenn2008
General Tech Questions
19
Apr 10, 2021 08:36 PM
ChocolateTaco
Sep 21, 2020 09:53 AM
G37ampandmusic
Jan 9, 2020 04:08 PM
myjee37
Sep 7, 2019 01:26 AM
ryanwhite74115
Nov 22, 2016 03:55 PM
