Bypass for airbag light
Old May 2, 2020 | 08:30 PM
dailyg37's Avatar
dailyg37
Help me out Im Tired of the light flashing. I’ve tried everything . I’ve seen bypass where to buy thanks
Old May 3, 2020 | 09:03 AM
dailyg37's Avatar
dailyg37
I’ve tried the Ignition reset doesn’t work. Tried using Snap On Scanner to clear code, doesn’t work. Something do with passenger seat. Disconnected battery unbolted seat and made sure all connections were plugged in
Old May 3, 2020 | 09:11 AM
SonicVQ's Avatar
SonicVQ
If you have a cheap wifi or bluetooth OBD scanner you can use this $15 app with a the enhanced diagnostic $15 plugin to read the codes from the SRS module and clear codes:
Old May 5, 2020 | 12:01 PM
Surfnazi's Avatar
Surfnazi
why not just replace the sensor
Old May 5, 2020 | 12:12 PM
dailyg37's Avatar
dailyg37
part number ?
Old May 5, 2020 | 01:08 PM
SonicVQ's Avatar
SonicVQ
In some cases if you can't clear the code, it is actually clearing and then setting.
Do you know what the SRS code is?
Old May 6, 2020 | 05:23 AM
Surfnazi's Avatar
Surfnazi
Originally Posted by dailyg37
part number ?
its the seat airbag sensor call Derek at grubbs
Old May 6, 2020 | 12:45 PM
dailyg37's Avatar
dailyg37
Old May 14, 2020 | 02:09 PM
Surfnazi's Avatar
Surfnazi
did you buy a new sensor
Old May 14, 2020 | 06:58 PM
dailyg37's Avatar
dailyg37
part number or link? I couldn’t find anything but some bypass
Old May 15, 2020 | 02:21 AM
crookncastle's Avatar
crookncastle
the occupant sensor on these cars are part of the seat pad and can only be replaced as part of the entire passenger seat. giant ripoff scam on infiniti's part for not making a replaceable seat pad or sensor. there is a thread in the forum about installing a emulator that can trick the srs control module and the srs sys will then operate normally.
Old May 15, 2020 | 09:02 AM
dailyg37's Avatar
dailyg37
Looks like just a plug in and go
CANT COMPLAIN
G37 Convertible
Jul 22, 2019 12:24 AM
jms515
Mar 8, 2013 02:20 AM
eauty
Feb 18, 2010 11:18 AM
ohseedee
Nov 16, 2007 09:54 PM
EdmiesterC
14
Oct 9, 2007 10:59 AM
